Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Truck of water
    Jun 2015
    Burke VA
    54
    Truck of water
    Hey TFP, pool will be filled with water next Tuesday from a truck. It's time to put all my research to work. I have a TF 100 TEST kit. I'm thinking that once the pool is filled I'll check all ph, ch, cc, alk cya. Than just start dumping chemicals in and run the pump for 48 hours and check every day to see any change. If someone could guide me towards a thread if this has already been covered would be appreciated.
    Above Ground Kayak Pool 12 x 24. 10,000 gallons.
    Northern Virginia
    TF-100 Test Kit
    sta-rite 27002-0100S filter
    Sta-rite 1.5hp pump
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Truck of water
    You won't need to test the CYA until a little while after you add some. Congratulations on your new pool, and YAY for the proper test kit!
    Jun 2015
    Burke VA
    54
    Re: Truck of water
    Thanks, so tap/truck water has no cya already in it? and after adding cya, it usually takes a week to register fully on a test. Should I add chlorine based on my expected cya?
    Northern Virginia
    TF-100 Test Kit
    Sta-rite 1.5hp pump
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Truck of water
    That's usually what they recommend. After it dissolves fully.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Re: Truck of water
    Yes. Add enough CYA to get to your target. It will take several days before it shows in testing. It is in there. Use Pool Math to work on everything else. Dose with chlorine to hit that target. Keep pH in that 7.5 area.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jun 2015
    Burke VA
    54
    Re: Truck of water
    I plan on using borates as well around 50 ppm. Should I do that after all levels are where I want them go be or at day 1
    Northern Virginia
    TF-100 Test Kit
    Sta-rite 1.5hp pump
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: Truck of water
    If your pool is cement/gunnite/plaster I would suggest waiting a little while as the pH bounces around a bit on new plaster. Let things settle and learn how your pool acts first is my opinion
    Aug 2014
    Northern IL
    4,615
    Re: Truck of water
    Add borates once everything is good and STABLE, especially TA. Once the borates are in there, your TA will be harder to change. Make sure your pH is stable too. (Btw, since adding borates to my pool early last season, I have never had to adjust my pH or my TA. I don't have a SWG and rarely use my water features which helps...)
    Is the tanker bringing regular water or "pool" water? I am wondering because there is a company in my area that does do "pool" water and it already has CYA.
    If your pool has been recently redone, you will need to follow the pool builder's recommendations to protect any warranty.
    Jun 2015
    Burke VA
    54
    Re: Truck of water
    I'll have to check on that, btw it is a above ground pool. And it's a vinyl liner. I know I haven't created my "signature" yet. Been busy reading all this great material on the forums. I actually think I'm looking forward to taking care of my pool more than swimming in it. Look what you people have made me become.
    Northern Virginia
    TF-100 Test Kit
    Sta-rite 1.5hp pump
    Aug 2014
    Northern IL
    4,615
    Re: Truck of water
    It's fun, ain't it?
    Jun 2014
    International Falls, MN
    15
    Re: Truck of water
    congrats on the new pool...
    since you are vinyl lined, start with getting your ph to 7.5, add enough bleach to get up to 3ish (right away), and mix your cya with HOT water to desolve it quicker (a pound or so per 4-5 gals of water-- stir and wait and repeat... it won't desolve in the pail it it greatly speads the process) shoot for 30 cya to start and that way if you have to neglect your pool for a couple days and are forced to use pucks to hold the chlorine level (tricolor or dichlor) your cya will stay below acceptable norms... once the pool water has stabilized near 7.5 / 3-4 & 30ish then you can worry about the TA... see the calculator to get an idea of how much and of what to add http://www.troublefreepool.com/calc.html
    ~ bright~ My new pool: 27' AG ; 19,500Gal w/ Haward 1 1/2hp 2 speed pump; generic sand filter, Pentair MiniMax 100 natural gas heat, following TFP chemical balance numbers using BBB and a little of my own magic ~
    Sep 2013
    Connecticut
    728
    Re: Truck of water
    I've read other threads stating that CYA, in the quantity needed for an entire pool, won't dissolve in a bucket of water, even if you use very hot water. Previous poster, what have you observed when you try the procedure you describe?
    I have noticed that the CYA I put in a sock in our newly filled pool at the beginning of the swim season dissolves very slowly at first (when the water is around 60 degrees F), and much more quickly when the water is warmer. However, that observation is in thousands of gallons of water, not in a bucket.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Truck of water
    Quote Originally Posted by far3171 View Post
    Sent from my HTC One_M8 using Tapatalk
    What kind of pool is this? Please let us know, but add those details to your sig line. Some things may differ depending on what type it is. Are you assured there is no metal in this water being trucked in? I would double check that. What is your reason for trucking in just curiously..?
    Although they may be great for you, there is no need to rush and assume you want borates. They are very optional.
    Essential Links:
    Jun 2015
    Burke VA
    54
    Re: Truck of water
    The pool is a above ground kayak pool with vinyl liner. I'm getting the water trucked in because it was included in the price of the pool.
    Northern Virginia
    TF-100 Test Kit
    Sta-rite 1.5hp pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,626
    Re: Truck of water
    Please do NOT put the CYA in a bucket. You do NOT want to take the chance of any of it sitting on the bottom of your new pool.
    Put it in a sock and hang it in front of the return. You can and should give a few squeezes when you are out there.
    Kim
    Jun 2015
    Burke VA
    54
    Re: Truck of water
    Can you please link which cya I should be buying. I saw this one online but I believe it's in liquid form https://www.google.com/search?q=cya+...55803511114295
    Northern Virginia
    TF-100 Test Kit
    Sta-rite 1.5hp pump
    Jul 2012
    Tallahassee, FL
    30,626
    Re: Truck of water
    I just did a search for kayak pools! Can you please post a link to the one you bought? They look so neat!
    I can't wait to see a pic of YOUR pool! Hurry!
    Kim
    http://www.walmart.com/search/?query=pool%20stabilizer&typeahead=pool%20sta
    This should be a link to Walmarts CYA
    Liquid is faster but it costs more.
    Jun 2015
    Burke VA
    54
    Re: Truck of water
    http://www.nassaupoolsandspas.com/wp...yak_pool01.jpg that's probably one that is closest to the one I got, unfortunately in ground was not possible in my area so I went with above ground. The contractor said it takes one day to build. I'll post a time lapse video once they are here on Tuesday. Before and after pictures as well.
    Is it safe to pour the liquid cya directly into pool?
    Northern Virginia
    TF-100 Test Kit
    Sta-rite 1.5hp pump
    Jul 2012
    Tallahassee, FL
    30,626
    Re: Truck of water
    It is once the pool is full and the pump is running.
    That is one neat looking pool!
    ONE day??? AND you are going to post pics??????? Sweet!
    Kim
  20. Back To Top    #20
    Jun 2015
    Burke VA
    54
    Re: Truck of water
    Should be exciting.
    Northern Virginia
    TF-100 Test Kit
    Sta-rite 1.5hp pump
