Thread: From the looks of the threads i have been reading, old wounds are about to be opened
    clutchman001's Avatar
    Jun 2015
    Meridian, MS
    22
    Hello all, we have had water in our new pool for about 2 weeks now, I have the TF100 kit and all of that is going well, my question is about...wait for it..BONDING..please stop throwing items. Hopefully this one is easy. My PB and myself did run the loop around the pool, we did connect said loop to ladder, stair rail, diving board, light fixture, as well as the mesh for the concrete deck, the two pump motors, but not to the swcg. He then connected the bonding wire to the ground rod. Is this correct, or shouldn't the swcg be connected, and the wire removed from the ground rod? I asked my electrician and he was not sure. I did print article 680 on swimming pools , hot tubs, and spas from the Mike Holt Enterprises link in on of the threads i read and we are in the process of reading over that. If this has to be a loop, do i need to connect each end back together with a brass lug type connector, to complete the loop? -- (My PB, my electrician, and myself!)
    18x36 Vinyl Liner In-Ground, 29,200 gallon, 2 h.p. Max-E-Pro P6E6G-208L Main Pump, Zodiac Pool Systems Booster Pump, Hayward Pro Series S244T Filter, Hayward AquaRite AQR15 Chlorine Generator w/T-Cell 15, Polaris 280, TF-100 w/Speed Stir, Taylor KF-1766 Salt Test
    22,553
    Re: From the looks of the threads i have been reading, old wounds are about to be ope
    While bonding and grounding are two completely different things, The bond wire isn't required to be connected to a ground rod, but it doesn't prohibit it.
    The loop is required around the pool but not around the equipment. You can run a branch off the loop around the pool to all the equipment. And yes the swcg should be bonded also.
    Jun 2015
    Meridian, MS
    22
    Bama Rambler, I think i may need to expand a little, all if the items i listed are connected with the one continuous loop, my PB just put the two ends to a ground rod clamp on the ground rod, i would not let him cut the excess off till we got this figured out, so adding my swcg will be relatively simple, i have an extra termination lug , so theoretically i could close the loop. The ground rod thing was just throwing me off, as like you said, not required, but not prohibited. Hey, we are practically neighbors, and a Trekkie too!
    22,553
    We are practically neighbors. I've been to Meridian more times than I'd care to count. My inlaws were Peavey dealers so I made many trips there and back.
    Add the swcg and since you already have the ground rod I'd leave it connected and close the loop. That way you're sure everything stays bonded even if the loop gets broken in one place.
