Thread: Hayward Sand Filter - gurgle/bubbling noise
    Jun 2015
    Ottawa/Ontario
    339
    Hi all
    Is it normal to hear a bubbling-like noise jn the sand filter? It mostly happens when I turn on the pump in the morning....
    90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Hayward Sand Filter - gurgle/bubbling noise
    Does the pump have to prime itself every day it starts up? If so, you have a leak somewhere on the suction side and its causing the pump to lose prime and then when you turn it on it's pumping air into the filter till it's all primed and running.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Does it sound like popcorn popping in the valve on the filter. If so the last posting is right. If the sound continues all the time the flow rate through the valve is faster that the valve is rated.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jun 2015
    Ottawa/Ontario
    339
    I will re examine once we resolve the suction side leak. It sounds more like a gurgling rather than popping
