Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Hi, new pool
    Jul 2015
    Grand Rapids, MI
    13
    Hi, new pool
    So I have a new used pool. I got it because I have a labrador that loves to swim . It's a half hour drive and half hour hike to the closest place we can go and let him swim off leash. So I bought a used above ground pool. Nothing major 15ft round pool 4 ft deep. It has a single filter skimmer what ever you call it. I got it all set up and filled it up from my well. Fill up only took a few hours and we both went for a swim. After swimming I added 4 cups of 8% bleach as a recommendation to start. This is just regular bleach the same stuff I use to sanitize my RV water system.
    So I have a Taylor Complete FAS-DPD Pool Water Test Kit K-2006 given to me by a friend to use to maintain my water. I read the entire manual and found nothing that explains anything about testing my water and what to do about it. Quite honestly the whole thing left me frustrated. It mostly seems to want to give me the history of the company and the history of water testing and no simple instructions. The simplest instructions are in the top of the lid. Which I can follow but then it leaves me going OK so now what does this mean. Which says refer to the manual and I look at the manual and say So I am looking for some help.
    So I did the yellow test. Which says to use 10 ml sample for .002 ppm test and 25ml sample for .005 ppm test. Ok question number 1, so how do I know which test to use the .002 or .005? They both basically look the same add 2 scoops of the powder, and it turns pink. Then add drops of the next chemical until it turns clear. Then it says something about multiplying your drops and well there I am lost as well. Basically I did the 25ml sample and added 2 scoops of powder it turned pink and 1 drop turned it clear again. So what does that mean? I looked at this site and it has good information and what I can make out the yellow is my bleach level or FC level and I want that between 3-7. Which how do I translate that into 1 drop turned it from pink back to clear?
    I did test my PH and that was 7.0 2 days ago fresh fill but it is 7.6 today. I am guessing this is normal?
    I did the green test, it took 35 drops to go from greed to red. Ok so what does that mean? is there someplace that just lists a number of drops to what you need to do?
    The other tests I didn't do I figured I would just kind of start 1 test at a time and try to figure it out.
    I know though that this is not a big pool so kind of like a small aquarium vs a large aquarium so changes in my pool are going to happen fast. So any help please translating this?
    Jun 2014
    15,178
    Re: Hi, new pool
    Hello and welcome! Lets' try to answer your test questions:
    - PH ideally should be between 7.2 - 7.8. It probably jumped high because your TA (35 drop test) is high; the TA helps to keep the PH stable
    - The powder scoop test is very important every day. It checks yoru available chlorine. For example, say you put the power scoop in (now it's pink), and it takes 16 drops to go back to clear (16 x .5 = 8). Your FC = 8.
    - You need to do a CYA test. Should be with a skinny vile that has a black dot at the bottom. You'll love this test. But it's very important.
    Find your CYA reading, then go to this chart Pool School - Chlorine / CYA Chart. Find your CYA and its corresponding FC level, and that is the FC level you always want to maintain with liquid bleach.
    That's a start for now. Don't want to overload you. .
    Whenever you need to adjust something, you can look at this chart for a reminder of what to use: Pool School - Recommended Pool Chemicals
    Jul 2015
    Grand Rapids, MI
    13
    Re: Hi, new pool
    Ok Cool thanks, so the TA is high caused my PH to rise, got it easy enough. From what I can make out I need to add Muratic Acid, which I have some and this will lower the PH and also the TA and it is probably going to raise the PH again until I get things stable? Will do the CYA test when I get home. How many drops should I be on the TA test? Whats my goal in drops? I understand you want some because it keeps the water stable but what should I be aiming for. 10 drops? 20 drops?
    Oh and it says add acid then aerate to bring ph back up. Am Aerating by just letting the filter run a few days, or am I sicking the hose out of an air compressor in there making bubbles? Not sure if there is like a tube or something with holes in it that lets bubbles go up I need to buy? I am thinking aquariums, only way I know how to aerate an aquarium is with air bubbles.
    Apr 2015
    Niskayuna, NY
    63
    Re: Hi, new pool
    On my K-2006 test kit the step by step instructions are on the inside of the lid of the box. Is that what you are following? Read the pool school articles on this site to get an idea of what values you want to shoot for. People here recommend using a 10ml sample for the chlorine test. That way, each drop counts as .5 ppm Chlorine. If you used the 25ml sample and it turned clear after one drop, then you have .2ppm free chlorine.
    18x36, 21,000 gallon, in-ground, vinyl, Pentair SWG, DE filter, Pentair 250K Heater, Taylor K-2006, Dolphin Triton
    Jun 2014
    15,178
    Re: Hi, new pool
    Adjusting the PH and TA will be a cat & mouse game. You can add just enough acid to lower the PH to about 7.2 (don't go too low). At the same time it should lower the TA a bit. If your PH starts to rise, do it again, and again, etc until they finally decide to play nice and stay. You always want the PH somewhere between 7.2 - 7.8. The TA can be anywhere from around 70 -120-ish. As long as you get to where the PH stays in-place, then you can probably leave the TA alone.
    If you ever go too low on the PH, you can raise it with borax, soda ash, and/or aeration. Be careful with that acid. Nasty stuff (fumes and skin). Also do not add bleach or acid together. Bad mojo. Have fun!
    Apr 2015
    Niskayuna, NY
    63
    Re: Hi, new pool
    Quote Originally Posted by MyDogsPool View Post
    Recommended levels are found here: http://www.troublefreepool.com/conte...mmended-levels
    The TA value is 10ppm per drop, so you want to be in the neighborhood of 8 drops - but this is a less critical item than making sure that your FC is the right level for your CYA
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Hi, new pool
    Here is the recommended levels for you pool. Likely your pool is a vinyl (vinyl liner) sanitized with bleach. You will see the targets for all the tests in the chart.
    Here is the Chlorine/CYA chart. Once you determine your CYA use this for your target FC.
    In my opinion, this is how you should treat your pool. Use an old nylon full of stabilizer hanging in front of your return to add CYA. Use PoolMath to figure additions. et the levels within targets in this order:
    1st - ph
    2nd - CYA
    3rd - FC
    Stabilize the above, then work on TA/CH.
    4th - TA
    5th - CH is pretty much irrelevant in a vinyl lined pool.
    It's worth noting that CYA and FC can be changed at the same time. Your ph will rise the more your dog splashes and you can just keep adding muriatic acid (MA) to lower it. That will in turn lower your TA as well. Feeling overwhelmed is easy but don't let it bother you. As long as you get the the first 3 in line and then maintain adequate FC you have lots of time to dial the rest in.
    If the tests still seem confusing, there are often lots of examples on YouTube to watch and learn from. Congrats.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: Hi, new pool
    So nobody is going to comment on the 1 drop for the CL test?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Sep 2013
    Charleston, SC
    538
    Re: Hi, new pool
    I don't know if this is redundant to what your instructions say, but here is a link with all the directions for performing each of the tests Water Testing Instructions on One Page
    Good luck and you are in good hands and folks will help you out.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Sep 2013
    Charleston, SC
    538
    Re: Hi, new pool
    Regarding your yellow test which is the Chlorine test, you have .2 ppm of free chlorine in the pool and you should have between 3 and 7 ppm in your pool. If your pool dimensions above are correct, you have 5300 gallons in your pool and if you are using 8.25% bleach, you need to add 30 oz to get your CL level to 4 ppm. This will dissipate as you probably don't have any CYA in your pool yet, but let's take things one at a time.
    Pool Tool's Avatar
    May 2014
    757
    Re: Hi, new pool
    pabeader - the 1 drop was addressed in post #4. Is that what you are asking?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: Hi, new pool
    yepper! as much as I read these things and as careful as I am. I still miss stuff!!!!
    Pool Tool's Avatar
    May 2014
    757
    Re: Hi, new pool
    haha, no problem! For me most posts require a thorough read and usually a re-read.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,544
    Re: Hi, new pool
    I want to know how you get your dog in and out of the pool. Pics are very much welcome as well!
    Kim
    Jul 2015
    Grand Rapids, MI
    13
    Re: Hi, new pool
    Ok so I added the suggestions above 4 cups of muratic acid and four cups of 8.25% and let everything churn for about 5 hours. I know 3.75 cups were recommended but
    Maybe I did everything correctly here is what I got so far so let me know if you think this is correct or makes sense.
    PH 7.4, this is pretty easy to test so I am sure this is correct
    FC 13 drops added so that calculates 6.5 million ppm
    TA 29 drops. 290 ppm
    CH 22 drops 220 ppm
    CYA The last test well not sure if my results made sense its not really a hard test to do so not sure how I screwed it up. I did it twice with same results. You take the squeezable plastic container and you fill it to the 7 mark with pool water add the R-0013 to the 14 mark shake it for 30 seconds and then slowly add to the small container until you can no longer see the black dot. Well I can fill the whole thing up. I can still see the black dot. So not sure what that means. I did it twice. In fact it looks perfectly clear.
    Jul 2015
    Grand Rapids, MI
    13
    Re: Hi, new pool
    Quote Originally Posted by kimkats View Post
    Kim
    My lab does agility so he is very used to walking ramps and doing the dog walk. So I put 2 plastic dog ramps, they are made for getting in and out of vehicles, in they have like a textured paint on them on the tops but smooth plastic then they have straps on them already to like strap on car seat legs, I just strap to metal frame at top of pool. They are light weight and fold up so I can take them up when I am not out there with him. You can see them here Amazon.com : Petgear Travel-Lite Tri-Fold Pet Ramp 200 lb. : Automotive Pet Ramps : Pet Supplies but if your looking shop around I got the same ones at a pet expo for $30
    Jul 2012
    Herndon, VA
    419
    Re: Hi, new pool
    CH 22 drops 220 ppm
    Have you added any stabilizer? If you haven't, then you have zero CYA, which means your chlorine is going to burn up very fast in the sun.
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Jul 2015
    Grand Rapids, MI
    13
    Re: Hi, new pool
    Quote Originally Posted by GuinnessPhish View Post
    Well I believe I can answer that question with another question. Whats stabilizer?
    Sep 2013
    Connecticut
    728
    Re: Hi, new pool
    Having the CYA test come out perfectly clear makes sense, since you haven't described adding anything that contains CYA (also commonly called stabilizer). You should buy some CYA and add it to the pool - use Pool Math and figure out how much you need a get to about 30 ppm. The usual recommendation is to put the stabilizer in a sock or similar container, hang it in the pool, and let it dissolve over a few days.
    The CYA helps the chlorine in the pool last longer, so that free chlorine levels don't drop as quickly as they otherwise would in sunlight.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
  20. Back To Top    #20
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Hi, new pool
    Yes, add 30ppm of cya/stabilizer in a sock and throw it in a skimmer basket or hang it in front of a return, squeeze it a gew times a day to dissolve it and test it a week later. Be sure to raise your chlorine to target level for your CYA, Chlorine CYA Chart. Aim a few ppm higher with the dog. It is safe to swim up to shock level.
    Please add your pool info to your signature as shown here, Pool School - Getting Started
