Thread: Fountain recommendation for return?
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Hoping I could get some input, looking for a fountain that I can install directly to one of my returns in the pool. Pool temps down here in Florida are starting to creep up, so looking for a fountain to try and help keep the temperatures down a bit. not looking for anything permanent, just something that can easily plug into one of my returns and then be removed in a couple of months.
    reviews on amazon are all over the place, so figured I would ask here.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Fountain recommendation for return?
    I just have one of those 20 dollar flower head fountains. Run it at night and it does a good job-down 4 or 5 degrees.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    We're in the process of making a new one now that uses the same fitting as my Polaris 165 does.
    We leave this part in the return :6 500 00 Polaris UWF Connector Fits 180 280 380 165 65 | eBay
    Then we just ordered these parts Polaris Universal Wall Fitting Quick Disconnect 6-502-00 at Sunplay and Polaris Pressure Relief Valve 6-503-00 at Sunplay
    which we've attached PVC to to take the connection a "J" up to the surface and into a T. Skippy just hasn't drilled the holes in it yet.
    It clicks into the return in seconds because of using the same fitting. Less than $20 and should be an improvement over the return mounted fountain we have that uses a hose across the pool to work (and get in the way)
    Jul 2014
    Peoria, IL
    389
    I just built one out of PVC pipe fittings and pipe.
    Drilled holes in the pipe for the water to spray out and worked like magic a couple years ago.
    Have not needed it this year as it has rained nonstop and is 59 and raining today. Been in the money pit twice this year. We have plenty of cool water.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
