Results 1 to 8 of 8
Thread: Algae of some sort?? Can't brush off.....arghhh
    May 2009
    Chilliwack, BC, Canada
    57
    I went to clean my 16 x 32 vinyl lined pool and found I couldn't even brush the growth off. I originally thought it was just dirt laying in the low spots but even with vigorous brushing it does not come off. It appears dark to black at first then turns yellowish after brushing. I gave it a brush last night and threw 3 litres of 12 % in but this morning still is not letting go. Going to try to attach a pic.
    Please help!!
    16x32 Vinyl inground pool, 9-4'x10' solar panels, sand filter, Taylor K-2006 kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Algae of some sort?? Can't brush off.....arghhh
    Sound like some type of Algae, but what's been going on in the pool recently Chemical wise? Can you post up a set of full results please? Without knowing more, I'm betting on lack of good and consistent FC residuals recently.
    Essential Links:
    May 2009
    57
    I have been super busy lately and admittedly have been neglecting the pool. I will go and test now and post the results.
    Thanks for the reply!
    Stand by
    May 2009
    57
    OK....just tested and here are the results:
    FC=5.5
    CC=0
    TA=80
    PH=8.0
    Going out to adjust now....What are your recommendations? Shock and algaecide?
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    What is the cya level?
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yep, that's a critical number for sure.
    Essential Links:
    May 2009
    57
    Good call!!! Too low to read....heading to town to pick up some stabilizer and bring it up!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would make sure not to add more than you need to get to 30-40 TOPS, and be prepared to SLAM the pool.
    Essential Links:
