Thread: DE filter cycles are much longer following replastering last summer...is this common?
    Jul 2014
    Berks County, PA
    206
    Hi,
    I'm suspecting that, since the old plaster was in a pretty deplorable state, every time I brushed or vacuumed I was probably sucking in plaster debris. I am thinking that the plaster was constantly breaking down (also it was a constant battle with algae attacking all the pock-marked and worn areas on the bottom - it sort of looked like a coral reef down there). I experienced filter pressure increases nearly every 2 weeks or so, but so far this season with the new plaster the cycles are much longer. I cleaned the filter a month ago (I never just backwash....rather I take everything apart and hose off the grids, clean out the tank, pump strainer, etc.) and I'm still at the same pressure that I started with after adding new DE.
    What is the 'average' filter cycle length - if there even is such a thing? I do think that what I was experiencing with the old plaster - that of having to clean the filter every few weeks - was probably a bit excessive. Is it possible that now I might only need to backwash following a pressure increase and then take the filter apart every few cycles instead of at every DE change as I have been used to doing? Anyway, I'm loving the reduced level of maintenance! Plus the water seems so much cleaner and fresher (well, for one thing it was a fresh fill only about a year ago).
    Also, I have a question about leaving the grids in while away on vacation. Before the renovation, I always took them out for fear that the pressure would go up too high while I'm away from the pool for a few weeks. It's probably not an ideal way to run a pool since without the girds I'm basically just circulating water (and yet the water never looked too bad after I got home from a trip) But now since the filter cycles seem like they are going to go much longer, I was wondering if I'd probably be ok cleaning it good before leaving, adding new DE, and then just keeping the filter running with the girds in?
    Keith
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: DE filter cycles are much longer following replastering last summer...is this com
    Glad your DE is lasting longer between cleanings! I suspect you're right about your old plaster decaying and then being the factor that was clogging up the filter more often last summer. I don't have a DE filter but with my sand filter I only backwash once per month at the most during the swim season. Perhaps other DE filter users can chime in.
    As far as vacation and grids, that would depend on how long you're going to be gone versus how long you're going to be gone. If you're going a month between cleanings and you're going to be gone for a week, I wouldn't hesitate leaving it run on filter while you're away as long as your chemistry is maintained while you're gone.
    Isolated Spa - 345 Gallons
    Jun 2015
    Wildomar, California
    423
    Most DE filters here in California are backwashed every 3 months. Unless, of course, you're that neighborhood guy where every kid comes to your pool to swim. LOL
