Thread: Generic pool finishes
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    We like the idea of upgrading the pool surface from a basic plaster to something that will last longer before needing to be resurfaced. My understanding is that quartz aggregates like Diamondbrite or Quartzscapes add some longevity, but pebble adds significantly more. Is that correct?
    If we determine pebble is the best and we don't mind the added roughness (I would appreciate firsthand opinions on this too, please!), we are wondering if we can get a good result by using a generic pebble instead of name brand like Pebble Tec for the cost savings. I know there would be a warranty difference, but if we are not attached to a brand name, might this be a good option?
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Generic pool finishes
    Stick with top brand like CLI, or NPT if you really want Pebble and don't want a PT price. Comparable, or arguably better than PT is WetEdge, so that might be an option to consider. Likely not a lot of savings, but possibly some. Quartz is a fantastic option for in between plaster and pebble, so don't dismiss it entirely. I love mine, and would likely choose it again over pebbles.
    Essential Links:
    JamieP's Avatar
    May 2011
    1,135
    Thank you, Patrick, for your insight. How does your quartz feel on your feet? I've heard it is rougher than plaster but not as rough as pebble. Is that your experience?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's actually smoother than some older plaster pools I've been in. Worlds smoother than any pebble finish for sure. Even the micro fine pebble finishes. It's very nice.
    Essential Links:
    Nov 2011
    Moberly,MO
    1,010
    Look at http://www.ecopoolfinish.com this is a plastic finish that chemical balances won't bother
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    It's more of a grainy feeling to me
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
