Results 1 to 11 of 11
Thread: Ice on cover of inground pool
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Hey guys,
    Can ice be harmful if it sits on the cover of an inground pool too long?
    I don't have one of those cool covers you can walk on. this is an old school cover that floats on the pool and is held on by water bags
    I live in NY and we had so much snow and ice this year that it won't unfreeze. So Ive had about 6 inches of frozen water on the cover all winter. Normally this wouldnt bother me cause it melts and I pump it off. But this time it never melted.
    I guess my question is, can the ice expand and put constant pressure on my liner, doing damage? Is this a concern?
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Feb 2009
    Kamloops, B.C., Canada
    22
    Re: Ice on cover of inground pool
    I have little to no knowledge about this but I would think that the pressure of ice expanding wouldnt even be comparable to the pressure or 20000 Gallons of water pushing on the sides.. I think its fine. but I am no expert
    my pool: 18x32 20,000ish Gallons with a 3/4HP pump and sand filter. 1 skimmer 2 returns. Cheap Ebay Kreepy Knock off. Rookie BBB user.
    The ice isn't a problem as long as you have the cover adjusted so that most of it's weight is supported by the water. If the cover is held up above the water, the weight of the ice can occasionally damage the springs. While everything is frozen you should lower the tension on the springs and allow the cover to be supported by the water/ice in the pool. As long as you do that everything will be just fine.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    If the pressure around the edge is enough greater on one side, the walls can fall over.
    On an Inground pool? That would be disasterous, do you mean on an Above ground pool?
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Sorry, somehow I read in-ground as above ground. Corrected information is above.
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by jschapansky
    An inground pool is mostly braced by, well, the ground; the sides of the hole it's in.
    Pretty strong. The situation at the top of the walls is a bit different, I'd think
    a thick enough ice sheet could potentially crack something.
    The cover would suffer first, though, which I think was the original question.
    If there isn't enough play around the edges, it might split.
    --paulr
    BBB "Intermediate Swimmer"
    allaboutcovers's Avatar
    Jan 2009
    Houston, Texas
    3
    Water or ice on any type of cover be it an above ground pool or in-ground pools will displace the water in the swimming pool (imagine taking a full glass of water and then putting ice into it) causing it to rise and drain off into the overflows or even onto the decking. Any water or ice on the surface of a pool cover should be removed as soon as possible to eliminate any damage to the cover as well as keeping the swimming pool area safe.
    We are All About automatic swimming pool safety Covers.
    allaboutcovers.com
    Quote Originally Posted by allaboutcovers
    I mostly agree about water, you don't want too much accumulating. But with snow and ice there usually isn't any practical way to remove it without risking more damage than the snow/ice is likely to cause. A snow shovel is far more likely to go through the cover than snow alone is. And anything that is solid enough to deal with ice is even more likely to cause damage.
    Jan 2009
    Cupertino, CA
    1,966
    What, you don't lower the water level before putting the cover on? That's what we
    did with our inground pool when I was a kid. The winter's accumulation typically
    wasn't enough to get back up to the normal water level.
    Also the ice-in-a-glass-of-water analogy isn't really correct, as the glass of water
    doesn't have a cover on it.
    I think I remember using a big push broom for snow. Ice was hopeless.
    --paulr
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    OK, We have 3 feet of snow ontop of my cover and I did remove most of the snow but you cant remove all the ice and snow on the cover. It will not hurt the liner. As Jason stated, you are more likely to cause damage with a shovel than the snow/ice itself. I use a shovel until I get about a foot left. Then I pulled out the broom and pulled off as much as I could. There still is about a foot in through the middle, but that wont hurt it any.
    You should be fine.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Thanks everyone!!!!!
    We of course lowered the level of the water. My only concern was the ice expanding and putting so much pressure on the pool that it would damage the liner. Not the walls or anything.
    Anyway after reading everything I am no longer concerned about this.
    Thanks again!
