Thread: Illinois Green Pool
    RookieSLAM's Avatar
    Jul 2015
    Albany, Illinois
    3
    Illinois Green Pool
    Hi Everybody,
    Well, I have a green pool to start my second year. First time doing the BBB method, last year just went by the local pool store recommendations. Here are my test results I took today about 20:50 cst.
    CL = 1
    PH = 7.5
    FC = 1
    CC = 1
    TC = 2
    CYA = 40
    TA = 150
    CH = 250
    I added 484 oz of 8.25% bleach on Saturday. I had test results ran at the local pool store the same day and told them my situation. Out of frustration, I went with their recommendation of using a whole container of Yellow Out ( 3 or 4 lbs). The pool seems to look better, blueish green (currently). Before I do anything else, I am finally sitting down and taking the time to register and ask for some help. If I did everything right, it looks like I should add 346 ounces of bleach to truly start the SLAMing process. I will really appreciate any and all help, Thank you!
    15,300 G, AG, 1.5 HP ClubPro Pump,
    SwimPro H.E. Sand Filter, Lil Shark Cleaner,
    TF-100 Test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Illinois Green Pool
    Yes, slam away. Sounds like you have read up but here it is just in case, Pool School - SLAM - Shock Level And Maintain
    Jun 2014
    15,156
    Biggest piece of advice .... MAINTAIN that FC level for a SLAM. S0 with your CYA of 40, that means keep your FC at 16 while running the pump 24/7. OF course scrub/brush your pool often and clean the filter a little more often and you will succeed. But maintain that FC level! Oh, and take before and after pics of your SLAM if you can. The crowd here loves those.
    RookieSLAM's Avatar
    Jul 2015
    Albany, Illinois
    3
    I will try and post some pictures. Hardest part now is trying to maintain the right levels while working.
    So, On the FC test I was adding drops to go from pink to clear. I would add a drop, it would turn clear, then a few seconds later it would be a light pink tint. Do I wait until it stays clear for a certain period of time?
    Thank you for the advice
    TF-100 Test kit.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Bring the pH down to 7.2 before you start the SLAM. Understand you may have a higher chlorine demand early in this SLAM because of the Yellow Out. It is an ammonia type product that creates high chlorine demand.
    Support the site
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    We're going to have to start an Illinois vs. Texas head count soon
    Welcome, glad you started a thread. We are all happy to help and see your pool turn enjoyable.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
