Results 1 to 9 of 9
Thread: Hayward 6060 booster pump leaking at top
    Jul 2015
    Conshohocken, PA
    1
    The pipe going in the top has a leak. When I turn the cleaner on the water spews out. Tonight I took it apart and the o-ring was laying on top of bottom pipe. Put o ring back in place, still leaking just not as bad. Is this as simple as replacing the o-ring?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hayward 6060 booster pump leaking at top
    Welcome to the forum!
    Sure sounds like it would be worth a shot in this situation. I'd give it a try for certain and see what happens.
    Essential Links:
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    I am assuming that the union is being used. The o-ring should solve the problem. Here is a link to the manual
    http://www.hayward-pool.com/pdf/manu...rPump-6060.pdf
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    May 2015
    Austin, TX
    30
    Quote Originally Posted by Hayward Pool View Post
    same pump, same problem for no apparent reason. Changed o-ring, still leaks. Oversized o-ring, still leaks. I am thinking it is possible a crack in the union piece, but I will have to cut the pipe off to see the fitting and inspect. I sure hope it is not the threaded port on the pump as that is part of the pump housing.
    16x30 gunite/plaster, 15,500 gal, Flagstone coping, 3'-6' depth plus bench and sundeck, bubbler, Hayward 1-1/2hp 2pd Tristar pump, Hayward 550 cartridge filter, 320 Chlorinator, Smart Ozone Sanitizer, Hayward Viper cleaner, 1 skimmer, 2 drains, 3 returns, 1 deck bubbler, Hayward booster pump for cleaner. Taylor K-2006 test kit.
    May 2015
    Austin, TX
    30
    just reading this, it tells me this must be an inherent problem with these. Too too coincidental.
    Oct 2014
    Elizabeth
    426
    I checked with engineering and technical and nothing has been reported. Let me know if you find something.
    Hayward Pool Tech
    May 2015
    Austin, TX
    30
    I bought a new Hayward 1-1/2 union AX6060UNPAK and problem solved. Of course I had to create a new pipe section and add a union. Why Hayward makes us buy two of these in a kit is kind of a rip off. As I only needed the one.
    May 2015
    Austin, TX
    30
    FURTHER UPDATE, started leaking again. Bought a new volute thinking the fitting on the volute may be the problem. Installed and still leaks, so with a new volute, and a new line fitting, I am a at a complete loss. I did notice just tilting the pump slightly can cause it to leak. This means the fitting must be completely level and flush, but again this is almost impossible to do. I am going to try and find a better o-ring to see if this helps otherwise I will just go buy a new Polaris pump as I never had this issue with them.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Have you tightened the you know what out of the threaded connection? Use pipe dope (shouldn't need it but wouldn't hurt) and lubed up the o-ring good with a silicone lube (don't use a petroleum based lube like vaseline)?
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
