Thread: Patch return line at fitting?
    May 2015
    Abbotsford, BC
    17
    Well the leak guy came out and found our leak in about the first 10 minutes: where one return line comes in, the nozzle fitting appears to have not been attached properly (bad glue job maybe?), or may have pulled loose with settling and shifting... and someone in the past seems to have "repaired" it with Fix-It Stick or some sort of other hardening material.. and now that material is cracked or loose or in some other way allowing a slight trickle escape.
    Obviously to re-fit it properly means peeling the liner back, digging down to the pipes, etc. That can be something left to the pool pros for the off-season.
    Meanwhile, I need to find some way to keep it going through the summer without needing to top the pool up every day. I'm thinking to chip out the old stuff and use a bead of Sikabond (immersible polyurethane), which is super sticky and stays flexible... only catch is, it's supposed to have 4-7 days to cure fully, and with the hot weather, I really don't want to be without the pool for that long.
    Can anyone offer any other tips for a quick, temporary patch? I haven't chipped the old stuff out yet to confirm what kind of gap there is....
    "After a time, you may find that having is not so pleasing a thing, after all, as wanting. It is not logical, but it is often true."
    Pool: 80,000l (21,000 USG) 32'x'16' in-ground concrete with vinyl liner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Patch return line at fitting?
    Sorry I can't think of something at the moment, but is the leak acceptable until you can have downtime on the pool?
    Essential Links:
    May 2015
    Abbotsford, BC
    17
    Well, I went with the urethane... nasty stuff to work with, went through three latex gloves, but I think I got the gaps all filled nicely. Letting it cure for the rest of today, then I'll plug the outlet and start filling the pool back up, and hopefully the city doesn't come pester me because of watering restrictions (pools aren't on the restriction list)...
    May 2015
    Abbotsford, BC
    17
    Two days later and all is good! Only a very slight loss to evaporation (maybe 1/8" at most)!
