Thread: Flex PVC
    Flex PVC
    My local HomeDepot sells flexible pvc pretty cheap. Problem is it slightly ribbed on the outside, will that cause a problem when trying to glue the fittings on?
    This is what it looks like
    Thanks
    John
    24' AG, Jacuzzi CRF 750 Filter, Magnatek 1.5 HP 2 sp pump
    BBB Method
    Mar 2007
    Ontario
    211
    Re: Flex PVC
    Here that is called "tiger flex" Thats what most builders around here use for all the plumbing.
    I have never heard of a problem in this area. Primed and glued properly and it should be alright.
    I have heard of insect problems with this pipe in different parts of the U.S.A
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Flex PVC
    We have regular PVC on our hard plumbing areas attached to the heater, and we have a section of that kind attached to the opening where our sump pump (rain water) exits the house. The ribbed stuff seems to discolor more and became brittle compared to the regular kind.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Flex PVC
    It will glue fine, but if the more pronounced the ribbing is on the inside the more it will add to the total head on your system. For that reason alone I'd suggest the smoother flex. I have also noticed a tendency for this stuff to get brittle faster as was mentioned.
    Re: Flex PVC
    The stuff I was looking at was completely smooth on the inside, the ribbing was just on the outside which I found to be strange. I just need a couple of small sections to complete some tricky turns with my pvc pipe.
    Thanks
    John
    BBB Method
