Results 1 to 16 of 16
Thread: First time using taylor 2006k
    May 2015
    Upper Marlboro, MD
    11
    Finally got one. Finally watched the video and now I have learned my pool is corrosive.
    FC 70
    CC 0
    PH 7.6
    TA 180
    CH 200
    Th black dot did not disppear - may not have had done this one correctly.
    What do I do? When I look at the calculation page I need another video..lol
    Help!
    24KIG; Plaster; DE filter; still learning. 1st time owning a pool. my first summer
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: First time using taylor 2006k
    Congrats on the pool and the new test kit!
    How does the water look?
    Why is FC 70? That is WAY high.
    TA is high and will likely cause PH to rise. When PH gets to 7.8 add muriatic acid to lower it to 7.2. This will cause TA to lower, Pool School - Lower Total Alkalinity.
    Add 30 ppm of CYA in a sock and put it in the skimmer, squeeze it a few times a day to help it dissolve.
    Here is a little reading,
    Pool School - PoolMath
    May 2015
    Upper Marlboro, MD
    11
    The water is very clear
    May 2015
    Upper Marlboro, MD
    11
    Apr 2015
    Quinlan, tx
    811
    An FC of 70 seems awfully high. Are you sure?
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    May 2015
    Upper Marlboro, MD
    11
    I multiplied by 2
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Quote Originally Posted by Tlarue321 View Post
    I multiplied by 2
    Sent from my SM-G900T using Tapatalk
    How big was the sample? If you used 25 ml of water, then FC is 7.0. The multiplier is .2 If you used 10 ml of water, the multiplier is .5, which would make it 17.5.
    Did the CYA sample get at all cloudy when you mixed half pool water with half reagent? If so, you have some CYA in there, just not enough. Raise it carefully in that case. Aim low. You can always add more later, but removing excess involves draining and rebalancing.
    May 2015
    Upper Marlboro, MD
    11
    Yes it is 7.0
    May 2015
    Upper Marlboro, MD
    11
    No it did not get cloudy
    Richard320's Avatar
    Jan 2010
    19,007
    Yes it is 7.0
    Then
    May 2015
    Upper Marlboro, MD
    11
    That means swim?
    Richard320's Avatar
    Jan 2010
    19,007
    That means swim?
    Yes. Hop in if you want. 7 FC is well below shock level for zero CYA. And if you have any CYA at all - any cloudiness in the test tube - even further below. You still need to raise CYA some, but you won't be losing any chlorine after dark.
    May 2015
    Upper Marlboro, MD
    11
    Cool.. what about the other readings
    Richard320's Avatar
    Jan 2010
    19,007
    These?
    FC 7 Above minimum and below shock level for <20 CYA = good
    CC 0 Perfect
    PH 7.6 Between 7.2>7.8 Good
    TA 180 High. Not harmful. Will go down each time you add acid to lower pH.
    CH 200 Lowish.
    CYA still waiting for an answer from you. Did it get cloudy at all?
    When I plug your numbers into poolmath, I don't see CSI as being corrosive to plaster. If you're worried about the low CH, you can try adding Calcium Chloride. I have never ever had to add CH to my pool, so my knowledge of that stuff is zero.
    May 2015
    Upper Marlboro, MD
    11
    Not cloudy. . But I need to rerun that one. I think I did it wrong.
    Apr 2015
    Quinlan, tx
    811
    The CYA test is hard. Watch the video and perform it during the day with your back to the sun and holding the bottle at your waist.
    I add calcium chloride to my pool. I must have real low calcium in my full water because I have a hard time keeping the CH up. It's easy to add and directions can be found in pool school.
