Thread: painted pvc pipe
    no-mas's Avatar
    Jun 2008
    FL
    405
    painted pvc pipe
    Hey Folks -
    I'm wanting to do a little work on the waste line from my multi port valve, but the pipe is painted. How do I best prep the cut end to apply the pvc cement? Do I sand the paint off, or is there some solvent I should use instead?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Sep 2008
    The Woodlands, Texas, USA
    243
    Re: painted pvc pipe
    Sand it down. As long as the PVC cement can contact bare, raw PVC you will be ok. Use the purple primer it you have it.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Yeah, I ALWAYS use primer.
    Thanks!
