Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: Any ideas why my above ground metal frame pool bust and how can I prevent repeat?
    Jul 2015
    Frederick, Maryland
    9
    Hello!
    I'm new to this form so forgive me as I try to figure it out!
    I have purchased three Intex metal frame above ground pools in the past four years (5,000 gallons). Each one has been fine for many months and then one day will begin rolling and within half an hour the seam connecting the wall and floor bursts. It always rolls the same direction. We had a concrete slab poured for the pool so it is on level ground. At first we thought it was because the kids were being too rough (cannon balls, waves, general kids pool behavior) but this time they were just floating/hanging out. It started to go a month ago so we drained the pool, re-positioned and had it refilled ($250!) but this evening it burst yet again. Has anyone had a similar experience? Any theories why this keeps happening? We had a large amount of rain recently, could it be connected? Is there a way to prevent it happening again in the future? Thank you!
    Intex ProSeries metal frame pool
    5,000 gallons on concrete patio
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Any ideas why my above ground metal frame pool bust and how can I prevent repeat?
    Hi, welcome to TFP! I see the pool is leaning toward the side with the ladder. Do the kids ever try to climb over the sides, sit on the sides, or jump off the sides?
    Love TFP? Become a
    TFP Supporter!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I never saw one lift the poles off the ground before. The neighbor had one that the poles bent, twice. They left it completely empty all winter and it buckled. (The second one) have you checked to see if your concrete pad settled crooked or something?
    Also, Proseries is different than Intex. Intex has thicker beams. You may want to try that brand, if you decide to try again.
    May 2015
    Cape May/New Jersey
    30
    That's pretty strange looking. Where are the feet for the posts?
    Jul 2014
    Oakbank, Canada
    389
    Strange, looks like the pool wall was pulled up. I wonder if someone was making tidal wave? Inflatable Pool Tidal Wave - Intex Easy Set Pool - YouTube
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2015
    mississauga
    19
    Are my eyes deceiving me, or are the legs completely off the ground and the pool bulging?
    Is it possible that the pool ground isn't completely level?
    16ft x 48in Intex Ultra frame Pool
    1500 GPH krystal clear pump
    Located in Mississauga, Ontario, Canada
    Jul 2014
    Oakbank, Canada
    389
    Yes, it appears the pool side is as least 1 foot lifted up and floor bulging out under the lifted portion. Be nice if photos were posted the right way up.
    I just do not see how that can happen all on it's own, especially more than once with different pools (unless the ground is extremely un-level and I mean extreme)
    domct203's Avatar
    Jun 2015
    CT
    3,591
    That looks like the result of an unlevel setup. Look at the water line, it's almost perfect across what I can see, but one side of the pool has it's legs lifted off the ground!!
    Did you confirm that the slab is truly level in all directions? My patio slab has a pitch for drainage.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2009
    Houston, Texas
    9,396
    Basically the pool has rolled so that it lifted the legs off the ground in the back and part of the front sidewall is under the pool. I think it may be caused by people climbing or jumping off the side near the ladder. This is not common behavior for an Intex style pool.
    Love TFP? Become a
    TFP Supporter!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,538
    Somebody's got some 'splaining to do.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    May 2015
    Cape May/New Jersey
    30
    I am still curious as to where the feet are for the posts. I've seen hundreds of pics of these pools in all sizes and styles and they have always had feet. Perhaps someone took them off after bulge to prevent
    it from popping it. But I would think the plastic feet would be better touching the bulge then metal. Or maybe they got ripped off by the bulge. Shrugs lol.
    I've got the 22x54 Ultra and at my former house it was on a hit and un-level as all heck. It looked more like a roller coaster then a pool.
    I had an 8 foot fiberglass slide with all sorts of kids making waves so much the water would run over the edge at the low side.
    So it's hard to imagine just being un-level as the cause.
    Seen 'zea3' post about people climbing or jumping off the side. For sure, jumping I would imagine would shake things up a bit.
    I think my next question would be about the "concrete patio". Is the pool directly on the concrete with no padding or sand? I can't quite see in the picture what the bottom is looking like.
    As others mentioned it's really hard to believe this could happen more then once even. Pretty crazy site it is. I reckon we'll wait on the answer to feet and concrete patio.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,538
    You can see one of the feet lying on the ground below the drain hole. They don't fit very tightly, and probably all fell off when the legs lifted off the ground.
    Pentair IC40 SWG
    Apr 2014
    FOUR cORNERS
    111
    My/Our pool liner has lasted over 5 years now, with some of the rowdiest playing I've seen, poles a flexing and maintaining and staying vertical, I just can't see how this happened if everything is right, and I see something is not rite.
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    A picture of the entire pool may be more helpful.....
    Casey's Avatar
    SW PA
    10,448
    I can't imagine this pool/slab being level at all. That's my assumption n I'm sticking to it.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,538
    Agreed. I don't see any other way one could roll over like that, even if you tried to push it over. Unless maybe one of the tee connectors on the other side rusted through and broke.
    Pentair IC40 SWG
    May 2014
    Owen Sound, ON
    44
    Is there any way that someone could be sneaking into your yard and using/abusing your pool?
    Have you considered purchasing a more permanent type of above ground pool?
    Intex 24'x12'x52" Ultra Frame (2014), 8400 gallons (31800 litres), Intex sand filter and pump, AquaBot Pura4xi, solar blanket, 32' x 10' deck across one side, 4' decks up short sides, better ladder. Proud owner of Hydropool Serenity 5 Hot Tub! Taylor K-2006 Test Kit.
    Casey's Avatar
    SW PA
    10,448
    Is it not odd to everyone that it looks level with it bulges out like that? So let's think about what it'd look like if It weren't bulging n the bottom weren't protruding. It'd be several inches out of level.
    Jul 2014
    Oakbank, Canada
    389
    Guess no one will know until the original poster answers again.
  20. Back To Top    #20
    domct203's Avatar
    Jun 2015
    CT
    3,591
    Quote Originally Posted by Casey View Post
    I'm with you Casey, there is no way that pool started off level..........
    Quote Originally Posted by domct203 View Post
    Dom
    Dom - TFP Guide
