Results 1 to 10 of 10
Thread: Robot cleaner and electrician
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    Do they need to do anything special so I can use the robot?
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Re: Robot cleaner and electrician
    BTW - They aren't for doing house chores. But you could try by talking really nicely to it.
    Though for the pool, you probably need to wait some time for the finish to cure, no?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    38,295
    Robots just plug into a standard GFCI outlet. You should have one near the equipment / pool (according to code).
    Please add your pool details to your signature as described HERE as it will help us help you.
    Mar 2015
    rowlett, tx
    853
    Quote Originally Posted by bmoreswim View Post
    Not sure what this means
    38,295
    Me either ... might be in the wrong thread
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Joke, - robot - Jetson's. My second thought was about waiting to use the robot. I wasn't clear on the question to be honest.
    Mar 2015
    rowlett, tx
    853
    Thanks for the info
    Will add the pool specs tomorrow from my computer. Usually post with my phone and don't see signatures so forget.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    LOL! I'm with you. Somebody must have a pool robot named Rosie. If not, we'll name Patrick_B's robot Rosie.
    jetsons maid - Google Search
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Quote Originally Posted by amandahein3 View Post
    Is there Robot School? Maybe it's somewhere here on TFP?! You probably need to be certified to operate one of those robots, yes?
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    DFW, TX
    24,497
