Thread: 1st test
    Jun 2015
    Estill Springs, TN
    14
    1st test
    I got my tf100 and just ran my first water tests.
    pH 7.2
    FC 10
    CC 0
    TA 70
    CYA 38
    CH 125
    I know I need to get my pH, TA, and CYA levels up buy which first? I have an Intex pool so is the CH allright at this level? Thanks!
    10,470 gallons @ 90%; 22' x 52" Intex Ultra Frame; cartridge filter 633T; May 2015
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: 1st test
    All those numbers are fine. Keep ph between 7.2 and 7.8 and chlorine at target or slightly above in the Chlorine CYA Chart. Oh, and swim a lot,
    Jun 2015
    Estill Springs, TN
    14
    Re: 1st test
    Thanks!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: 1st test
    Welcome to TFP!
    Your numbers look good, so enjoy the pool!
