Thread: Cloudy Water ?
    Jun 2015
    Ridgewood, NJ
    11
    Cloudy Water ?
    Hi-
    Water was crystal clear, but the PH looked low in the 6.8 range after a week of rain. I added 5 oz of soda ash yesterday (per calculator) by just sprinkling into the pool and not via the sock slow release method, and just let the filter run for 4 hours.
    Stats: 1800 Gal Intex
    FC: BT 5 and 10
    PH: BT 7.2 and 7.4
    Replaced filter on Sunday night, so I don't think that's an issue
    Can I assume the cloudiness is related to the soda ash being shaken up and after a few filter cycles will return to normal? Or do I need to take some corrective action?
    Thanks!
    Brian
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Cloudy Water ?
    Possibly. My PH was near 6.8
    I had to add 3 or 4 15lb buckets of PH up to get it to 7.5
    That clouded the water for a week, running pump 8 hrs a day.
    In hindsight I should have just run it 24/7 til it was clear.
    Dolphin E10 Cleaning Robot.
    Jun 2015
    Ridgewood, NJ
    11
    Re: Cloudy Water ?
    ok thanks, I'll just start running the filter now then, appreciate the fast response
