Results 1 to 7 of 7
Thread: Intex 12x24 paver measurements
    Jun 2015
    Stockholm, Sweden
    250
    Putting up a 12x24 Intex Ultra Frame shortly, still preparing the ground. Trying to find the measurements for where to put the pavers but haven't found them. I have all the other measurements but not the distance between the pavers, or better yet, the distance from center of one support leg to the next. (I.e. Center of one paver to center of next). Can anyone help out? Thanks
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jun 2014
    15,221
    Re: Intex 12x24 paver measurements
    Hello! Maybe I'm going-out on a limb here by using this example ....... but would it be better, after the ground-base is completed, to start setting-up the frame first? Get the skeleton of the frame in position first, then you could actually lift and place the pavers exactly where you need them - under each post. Or am I totally off track here? Wouldn't be the first time.
    May 2012
    Las Vegas, NV
    92
    ^ no you're not. that's exactly what I did and then had it leveled.
    perfect example ----> New Pool Build Questions - Page 2
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Jun 2015
    Stockholm, Sweden
    250
    Thanks guys, but no cigar. While that method works fine for the round pools, I don't think it is applicable for the rectangular. The frames are totally different and the assembly method also. In any case, I need the measurements for planning purposes before assembly. So please, anyone with a rectangular 12x24 who could bring out the tape measure?
    Thanks!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by Mickelin View Post
    Thanks!
    Good idea, as the rectangular ones bow in until completely full. I hope someone can help. Did you do a search and try to contact someone who has a thread about one?
    May 2014
    Owen Sound, ON
    44
    Quote Originally Posted by PAGirl View Post
    I went out and measured on the ground, centre to centre and I came up with 45"-46".
    Good luck.
    Intex 24'x12'x52" Ultra Frame (2014), 8400 gallons (31800 litres), Intex sand filter and pump, AquaBot Pura4xi, solar blanket, 32' x 10' deck across one side, 4' decks up short sides, better ladder. Proud owner of Hydropool Serenity 5 Hot Tub! Taylor K-2006 Test Kit.
    Jun 2015
    Stockholm, Sweden
    250
    Excellent, thanks PJ!
