Results 1 to 8 of 8
Thread: Rain rain go away!!
    Jun 2013
    Missouri
    15
    Rain rain go away!!
    Hello everyone! We have been trying to get this pool up for weeks! After numerous setbacks, we finally began filling about three days ago. We are almost to the point where the cut is needed for the skimmer. My dilemma is the rain. It rained all night and we are looking at two more days of rain. So what should I do now? Just wait or should I go ahead and place the stabilizer in the sock and/or add any chlorine? I don't want the water to get funky! Oh and we do not have a cover; however, we do have 90% of it covered with a tarp.
    Boonville, Missouri
    24x48 AG vinyl liner. Hayward XStream 1.5hp
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Rain rain go away!!
    Well, if you are going to be replacing or draining much water, then it's cheaper to keep a little free chlorine in there until you aren't. If you stay covered though, won't that keep rain out? If not, replace chlorine until it drys out some. With no Cya, it only takes 3 PPM or so to stay good, but if you get any sun, that will be gone in no time at zero Cya
    Essential Links:
    Jun 2013
    Missouri
    15
    So far, I don't think we will have to drain as we aren't even full yet. The cover that is on there is basically a tarp and it is holding only water right now (no leaves, bugs, etc). it is a square cover on a round pool, so there is a small spot uncovered on two sides. The sun hasn't been out today and rain is in the forecast for tomorrow, so probably be cloudy again. I just didn't want to pull that cover off and have the start of green water or algae since we haven't even got the skimmer hole cut, of course the pump isn't running.
    Boonville, Missouri
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Rain has zero effect on algae. Not sure where this myth originated
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2013
    Missouri
    15
    I apologize. I wasn't implying that the rain was the issue. My concern was with the fresh fill being covered up for days WHILE it rained, without being sanitized. Hope that makes sense.
    Boonville, Missouri
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    gotcha. remove the tarp and enjoy that free fill from the rain! just keep your FC up is all, no need to keep it covered at this point
    Dan
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    My Intex has been taking a few days to fill. (We went away for two days, didn't want to full while we weren't there) I added a little bleach and used the net to swish it around. It got me thinking about how people seem surprised that their pool can go green so soon after filling. It would be those, like me, who are taking more than two days to get it filled. It then goes quite a while with no chlorine. They count from the day they turned on the filter, not when they actually filled it. I didn't use very much cl., as there isn't any CYA in yet.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    no reason you cant keep the pool chlorinated during long refill. just add your bleach and use a brush to mix the water. it will be fine. you will lose more during the day with no CYA but just hit it twice and definitely get it up for the night hours so it can fight the algae without fighting the sun. to throw your CYA in from the get go.
    Dan
