Thread: check for leak
    Jul 2015
    Massapequa, NY
    1
    check for leak
    Hello to all,
    My nephew's German Shepard fell in the shallow end of my inground pool on Sunday. He attmepted to jump out where he fell in and cut the liner ever so slightly. However the cut is above the water line. Is there an easy way to check to see if his paws cut the bottom of the liner, what to look for, etc.? Thanks for any help!.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: check for leak
    Greeting, and welcome to TFP.
    Do you happen to have dive goggles for a closer look?
    I suspect a big sign would be if you start losing more water than normal evaporation.
    If you do a "bucket test" with pool water beside the pool in a bucket, you should be able to gauge if the pool level lowers faster than the bucket after a few days. If it does, closer inspection might be warranted.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
