Thread: Help SWG Not working
    zzrguy's Avatar
    May 2015
    Setauket , NY
    10
    Ok I have a My Blue Pool SWG and I am not making chlorine There are no lights other then the on light lighting up.
    Is there a way to test it I'm get voltage to the salt cell and if yes is it 12volt or 110 I do not have and paper work on this unit so I am at a lost.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Help SWG Not working
    The only info I can find is that it is a rebranded resilience swg. Do you have a picture of it? If it's like the resilience ones with the post and sleeve connectors on each side, you can use a meter on them to check the voltage. Most swg's are around 24 volts, but most/all of the resilience ones are 12 volt. I had a pool frog branded resilience swg prior to getting my circupool swg this year.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    zzrguy's Avatar
    May 2015
    Setauket , NY
    10
    Cool thanks ill test to see im getting any voltage
    16x36 in ground DE filter salt water MY Blue Pool SWG
