Plug in timer question
richierich
748
Long Island, NY
I bought a plug in timer for my Intex Cartridge Filter & Pump. This pump has the 'reset' and 'test' buttons on the actual plug that gets plugged into the timer.
I started the pump manually for 5 hours and it shut off correctly, but then the next day when its supposed to turn on it doesn't because the 'test' button was used when the timer shut it off. So I have to go outside and press the reset button on the plug and then it will shut off.
Will these timers only work with pumps that have an on/off switch on the pump with a regular plug?
Hope I explained this well.
yeah the plug-in timer is plugged into a GFCI outlet.
so the order is the pump (which has the reset/test on the plug) is plugged into the woods timer which is plugged into an outdoor GFCI outlet box.
I guess the only way to solve this problem is get a new pump, one that doesn't have the GFCI on the plug???
