Thread: Gunite vs. Shotcrete-Texas
    Nov 2014
    Dallas Texas
    165
    Hi all, we are in the final process of selecting a pool builder. The we are down to two and the price/amenities are within 3k of each other. One builder uses shotcrete and another gunite. If anyone has an informed opinion on the two methods and which is ultimately better with our variable texas soils, I'd love to hear it.
    Thanks!
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    Re: Gunite vs. Shotcrete-Texas
    Shotcrete is wet gun application vs gunite being a dry gun application. Shotcrete is mixed at the nozzle. Both are forms of concrete just applied in a different manner.
    102 Perimeter Freeform Pool, Rock Waterfall, Jandy Deck Jets, Depth 3'6" - 6', Stonescapes Aqua Blue Mini Pebble, Inpool Table, Rock Salt Decking, Jandy 2.0 Epump, Jandy 580 Cartridge Filter, Polaris 280 with booster pump, Jandy Power Center w/ PDA, Stenner Pump
    A country boy's pool build...Dean, Texas
    Apr 2013
    Sacramento, CA
    2,769
    In theory gunite has a higher compressive strength than shotcrete. However they are so close that it depends on the individual application. As long as you are using an experienced crew it really doesn't matter. A shotcrete pool surface will be rougher than an gunite pool, however that surface is covered by the plaster. Some large builders have their own shotcrete crews -- I am not aware of any PBs who do their own gunite. I would want a crew that all they did was gunite or shotcrete.
    As to differences -- in a normal pool with experienced applicators on a normal day and good followup for curing --- no discernable difference.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good workmanship, as mentioned makes the most difference, I agree.
    Essential Links:
