Results 1 to 9 of 9
Thread: How far can my pump/filter/heater be from the pool?
    May 2014
    Clarksburg, WV
    331
    So i have a deck completely around my pool. I'm looking to move the pump/filter from underneath the deck. I'd like to put it on a pad next to the house but its about 40'-50' away.
    I have a 1 1/2 hp Hawyard Matrix pump and a 180T sand filter. Looking at getting a Raypak heater shortly as well. I know IG pools have their equipment located pretty far away from the pool, and I dont see why I couldn't move my AG equipment farther away as well.
    Anyone have any pics of different setups like i'm describing?
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    May 2014
    Clarksburg, WV
    331
    Re: How far can my pump/filter/heater be from the pool?
    So let me rephrase this question.
    I have been reading and realize that if I use 2" PVC I can move it this distance.....I think. Will I need to get a new skimmer basket? I'm pretty sure mine is only 1 1/2". Or does that even matter? The skimmer and return are both 1 1/2" and all connections on my pump are 1 1/2". Will I need to change everything to 2" or just use the 2" trunk line between the pool and pump?
    Or can I just use 1 1/2" pvc and not have to change anything?
    TF-100 Test Kit
    How to SLAM
    Casey's Avatar
    SW PA
    10,457
    This is a great question for mas. I'd pm him the link or maybe he'll see It here. I know he stops in here often. I think the only thing you'll have to worry about is head loss due to any turns you put in the plumbing.
    Please post pics of your deck. I'd love to see it.
    May 2014
    Clarksburg, WV
    331
    Deck isnt 100% yet. Still trying to decide on railing, but i'll get some pics today when I get home....
    Its 3' wide on 3 sides of the pool and 12' long on the 4th side. I had a thread started a few weeks ago with some early pics of it....Maybe i'll try and find that and update it tomorrow.
    TF-100 Test Kit
    How to SLAM
    Jun 2015
    Houston, TX
    89
    Per the Hayward specs you will drop pressure and GPM with that distance.
    http://www.hayward-pool.com/shop/en/...ix-a-supowm--1
    It will work however.
    Model 10 ft 20 ft 30 ft 40 ft 50 ft
    SP1591 80 GPM 76 GPM 64 GPM 44 GPM -
    SP1592 86 GPM 86 GPM 75 GPM 58 GPM 27 GPM
    SP1593 91 GPM 91 GPM 80 GPM 62 GPM 32 GPM
    AquaMaster Deluxe 8000 AGP, 5500 gallons, 12x18. Liquidator and Pool Rover JR.
    1st Pool so go easy on me I'm using a TF 100.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Looks to me like that chart is for head pressure, not distance, can't click in right now.
    Use a fitting at the skimmer to go from 1-1/2" to 2" and you will be fine. 50' of horizontal distance is not an issue at all.
    May 2014
    Clarksburg, WV
    331
    I'm going to measure tonight and see how long it actually is. I need a better place for my equipment. My pool is in a weird spot in relation to my house and deck and porch and patio...lol I just don't have a good spot for a pump/filter/heater to sit without being in the way all the time.
    TF-100 Test Kit
    How to SLAM
    Casey's Avatar
    SW PA
    10,457
    Can you put it behind the pool so you can't see it from your patio?
    May 2014
    Clarksburg, WV
    331
    It's been raining every day when I get home so no pics yet, but behind the pool is the complete opposite side from the skimmer and its actually uphill as well. Hard to describe without pics I know...
    Here is my deck thread....
    New Deck Build. Figured I'd post some pics....
    Like I said....I need to update it. All the boards are on and the railing is getting ready to go up now.
    TF-100 Test Kit
    How to SLAM
