Results 1 to 8 of 8
Thread: I think I've fought off the algae, but I have a filter question...
    May 2015
    Macomb, MI
    14
    I passed two of the three criteria for fighting off the algae (FC/CC/OCLT) this last evening (I think I would've passed a couple days ago, but was out of reagent), but I still have the cloudy blue water. I can tell it is getting better, but it's taking it's dear sweet time. I've been running the filter (Tagelus 60 sand filter) pretty much continuously 24/7 since around the 27th or 28th (had a couple of nights off, because the pump got into a rhythmic hum that had me worried). I did backwash every other day and then I did about 3 days in a row, but my question is regarding pressure. It's clean pressure is 20, but it's not moving past that at all - eh, maybe 21. The gauge does go to zero when turned off and changes during backwash/rinse/waste. Do I need to backwash if that pressure isn't increasing? Should I be expecting pressure build up fairly quickly or does it just take longer than I'm expecting? I do have skimmer sock that I put on the skimmer the day before yesterday, but even before that, I didn't see pressure rising.
    Including some progress pics of the pool to show the TFP method works!
    16x32 IG Vinyl 22K gal, Tagelus Deluxe High Rate Sand Filter TA-60D, Jacuzzi Magnum Force 1MF-S pump, Hayward CL-200 Chlorine Feeder (NOT in use), Raypak RP 2100 Heater
    , K-2006 test kit
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    Re: I think I've fought off the algae, but I have a filter question...
    Backwash when pressure rises 20-25%. So around 25. The skimmer sock should be catching what the filer would have. Just let it run and it will clear up. Dirtier filter filters better than freshly backwashed.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    May 2015
    Macomb, MI
    14
    Thanks Joe. That's what I'd been reading, but I guess I just expected some pressure increase to happen faster. Patience...patience...which I've also read in so many of these threads. :P
    , K-2006 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    If you have passed OCLT and your CC is less than .5 it may be time to think about adding DE powder to your sand filter to allow it to filter smaller particles.
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    What Tim said ^^^^^^^^^^^^^^^^ You are right there now.
    Kim
    May 2015
    Macomb, MI
    14
    Thanks! I've seen references to doing this. I was trying to avoid spending MORE money, but at this point, hey - what's another $25.
    , K-2006 test kit
    Jul 2012
    Tallahassee, FL
    30,585
    LOL but this $25 will last FOREVER! I cannot even tell I have used any of mine!
    AND it will save you money--------------the faster you clear up your pool the less bleach you have to buy so...........LOL
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by brownhound View Post
    That's when you pester friends, family, and neighbors to see who has a DE filter. Then you beg a margarine tub or coffee can full.
