Thread: Cloudy pool
    Jul 2015
    WALHALLA sc
    2
    Cloudy pool
    My chlorine levels are really high and my pool is very cold can't see bottom. Any suggestions?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Cloudy pool
    Welcome to TFP!!
    We need a full set of test readings on your water to determineif it is "really high". The level of chlorine should be based on the amount of stabilizer in the water, not an arbitrary number like 1 - 3 as pool stores like to say.
    It would help us if you would add the following information to your signature
    • The size of your pool in gallons
    • If your pool is an AG (above ground) or IG (in ground)
    • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    • The type filter you have (sand, DE, cartridge)
    • If you know, tell us the make and model of your pump and filter.
    • List any other equipment you have: SWG, second pump, etc.
    • Please mention if you fill the pool from a well or are currently on water restrictions
    Support the site
    Jul 2015
    WALHALLA sc
    2
    Re: Cloudy pool
    1648 above ground and its a Coleman with cat ridge filter
