Thread: Hard water vs. Water softener
    Jul 2015
    Patterson, Ca
    18
    Water where I live is very hard at a 17 if anyone can relate that's my setting. Filled n set up with hard water but when i was let loose with it by myself the pool school said it was better to use my softener but a lil more use on the salt.Any ideas about this.also I'm a newb
    17k g, IG free formed, plaster/bella blue,varaible pump, cartridge filter, with water feature.New build 6/17/15 builder set start up and pump filter cleaning time. Runs 12am-2am clean cycle runs 2750 rpms n from 2am-8am 1200 rpms
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hard water vs. Water softener
    Do you have a test kit? One of the Recommended Test Kits?
    Use that to test your water for CH. In fact, post all your test results.
    A residential water softener can be used but it does not turn over fast enough to be viable to soften thousands of gallons in a single filling.
    Isolated Spa - 345 Gallons
    Jun 2014
    15,004
    Welcome back ARV! Sure, hard water can have its concerns on some pool owners, and no doubt certain locations are known for having exceptionally hard water. This can impact the shell of the pool and/or equipment and hardware. But that's why we emphasize testing and posting results to confirm if there's a need to be concerned. Since your pool is a new build, you certainly have plaster concerns and warranty issues to contend with. Have you seen our plaster start-up page: Pool School - Start-up New Plaster
    If you could post a full set of results with your TF-100 or Taylor K-2006 that would be great.
    Jul 2015
    Patterson, Ca
    18
    I'm using the 5 in one given at start up will order new test kit asap.but for now I've checked at Leslie's to compare to my results n are pretty close. Although they tried to sell me this pool stuff for 60 dollars for phosfrate I believe. Lol I laughed n just bought my acid.lol numbers chlorine ideal ph on the lower side but I just brought my alkalinity down from 8.2 to 7.6 took a couple weeks though. Leslie's says rest results are within peramiters. So I've all down shocked n now converting from tablets to bleach as of tonite. Thanks for all the help most of my questions were answered just by reading what an awesome site .
