Results 1 to 13 of 13
Thread: Hose keeps popping off
    Feb 2013
    Nashville, TN
    49
    We just returned from vacation. Left the pool pump and chlorine generator on a timer. Things were a bit dirty when we returned but seemed fine. Since we returned, the hose from the pump to the filter has popped off 3 times. What could be causing this? We've never had this problem before. How can we remedy the problem?
    Thanks for any advice.
    Sharkline Matrix 28', Pentair SD80 sand filter, Pentair Optiflo 1hp/2spd pump, Intellichlor ic40 (installed 7/2013)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hose keeps popping off
    How is it attached? We have several members with that pool, so they may answer before I can, but sorry I can't suggest something without being more familiar.
    Essential Links:
    Feb 2013
    Nashville, TN
    49
    Attaching a photo. It's the gray hose that keeps popping off from the top of the pump.
    Jun 2013
    SW OKC
    29
    Clean and dry both connections and tighten the hose clamp.
    18x48 Intex Ultra Frame, 6,423gal, 1500gph Cartridge, SWG, Setup June 2013.
    Casey's Avatar
    SW PA
    10,446
    Have you changed your hoses lately? If not, I would buy a new one.
    Cypress, Tx.
    154
    Mine kept doing that so I hard piped it with PVC. Problem solved.
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    I woud say, clean well (with maybe isopropyl alcohol) both inside of the hose and the fitting, and tighten the clamp. If the fitting is too tapered, maybe find another one.
    And, oh, check the pressure, maybe time to backwash.
    Cypress, Tx.
    154
    You could try double-clamping the hose also. The increases friction would probably prevent it from coming off.
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    Definitely double clamp. I came home to find one of my hoses came off---not fun to put 4-5 inches of water back into your pool from a 525' deep well.
    Learn from me. Double clamp, check periodically, or hardpipe.
    Good luck
    24x54 Sharkline Matrix
    Hayward 1 hp Powermax single speed pump
    Hayward ec50ac DE filter
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by morzh View Post
    **And, oh, check the pressure, maybe time to backwash.
    Was a thought I had, too.
    Feb 2013
    Nashville, TN
    49
    Thanks for all the responses. We have backwashed, checked the pressure (good), cleaned the hoses with rubbing alcohol AND double-clamped. It's been 24 hours and so far, so good. Next year I think we'll look at hardpiping it. Now we just need to get the water clean. After 2 weeks of vacation and a non-working filter system it is filthy.
    22,550
    If it does happen again, try using denatured instead of rubbing alcohol. It will take the glaze off the plastic so it'll grip better.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    I use dry (lab grade). Laquer thinner is good too.
    Do not use acetone, it dissolves plastics.
