Thread: In Ground Concrete Pool Rust on Stainless Steel Wall, How to patch/fix?
    Jul 2015
    Chesterfield / MO
    2
    Hello, I have an older pool(built in 1963) it's concrete floor, stainless steel walls, and has been painted with epoxy paint. I'm starting to get a couple of rust spots on the Stainless steel panels and on the joints of the panels. I've looked all over the internet trying to find out the best way to repair but haven't found anything. Hopefully someone can help me out on how to fix.
    Thanks.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: In Ground Concrete Pool Rust on Stainless Steel Wall, How to patch/fix?
    I do not have an answer for you, but wanted to say welcome to TFP and someone should be along shortly with some ideas.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
