Thread: Has anyone used the "Solar Roller"?
    Oct 2007
    Valrico, FL
    542
    Check out the website: here. I use a solar cover on my pool during the winter months to try to eliminate as much evporation as possible. However we do not have space around our pool for a normal cover reel. I was wondering if anyone on this forum has used this system and how well does it work.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Has anyone used the "Solar Roller"?
    I have one and it works fine for me. The whole key is cutting the cover to make it more managable. I can remove my cover in about 3 minutes using the roller by myself, and while I can deploy the cover by myself, it is much easier and quicker to deploy it with 2 people.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have one as well and I would echo jmas65's comments. Roll up seems easier than the unroll. Sometimes I need to adjust the cover by hand.
    Mark
