Thread: High TA Peeps: Is it possible to pre-filter makeup water to reduce TA?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Greetings, all.
    My friend is filling his new above ground pool with well water that we now know has a TA of 340.
    While I know what he'll have to do ultimately to reduce it, what I don't know is whether a pre-filter on the hose will help reduce the makeup water TA much.
    My own make up water is softened water by design, so I thought I'd ask those of you with high TA fill water if you've ever found pre-filtering useful.
    I have used this pre-filter as a safety to catch iron from my well if the softener regenerates during a top up. Would something like this be a good idea for him? Amazon.com : Pre Fresh Garden Hose End Water Filter all purpose, pool, spa, hot tub, pets, car wash : Garden Hose Parts : Patio, Lawn Garden
    Thanks in advance for any tips.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: High TA Peeps: Is it possible to pre-filter makeup water to reduce TA?
    Most pre-filters are cationic (positive ion) exchange resins so are good for exchanging calcium and magnesium and iron for sodium. To remove TA, you want an anionic (negative ion) exchange resin that can exchange bicarbonate ion with chloride ion (these are known as dealkalizers). Unfortunately, unlike water softeners, these appear to mostly be found in commercial units and not in something like a hose filter or residential unit. For example, Culligan Matrix Solutions HE is a smaller commercial model.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I wouldn't worry too much about the high TA, it will cause PH to rise quicker but the TA will come down as you keep PH in check. You can lower it faster if you aerate the water to force PH to rise, or just let it happen slowly on it's own. I have similar well water TA levels, after the first season I drained down for the winter, then in the spring I plugged all inlets/outlets and let rainwater refill the pool. My TA usually runs 100-150 throughout the summer. Late summer I usually have to top off from the well so that brings TA back up and I have to use more acid to keep PH right. It's just something I know about and don't worry over. I usually only check TA & CH about once a month anymore.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Thanks so much, guys! That helps a lot
    Helpful Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    You can buy A LOT of muriatic acid for the likely cost of that filter and I'm not sure how many gallons a single filter would dealkalize.
    Isolated Spa - 345 Gallons
    JoyfulNoise's Avatar
    May 2015
    13,251
    You could do what they do in an alkaline plaster startup and use a 50 gallon drum to pretreat the water with MA and add an air blower aerate it. But that would take an awful long time trying to fill a pool 50 gal at a time
    Matt
