Thread: Problem with Goldline T-15 Salt System
    Jul 2015
    Richmond Hill,Ontario, Canada
    1
    I have a GoldLine AquaRite system with a t-15 cell. My cell keeps on giving me a HI reading on the screen time to time. Whenever I check the Instant salt reading it gives me a level of 3900 ppm which is fine, so I recalibrate it, but after a while, it gives a High Salt reading again. Help would be greatly appreciated. Thanks
    I have a 20,000 gallon salt water pool with GoldLine AquaRite system with a t-15 cell and a Hayward sand filter
    Jun 2011
    Long Beach, CA
    2,790
    Re: Problem with Goldline T-15 Salt System
    Welcome to TFP!
    You need to measure the salinity with another type of salt test to verify the salinity. The 3900 level is at the high end and at times might cause the high salt error and you will need to drain about 10%-15% of the water.
