Thread: New construction newpool owner
    Jul 2015
    Patterson, Ca
    18
    Hello names Anthony, new owner of a 17000 gallon free formed pool with a variable speed pump n a water feature looking to learn how to care myself.
    17k g, IG free formed, plaster/bella blue,varaible pump, cartridge filter, with water feature.New build 6/17/15 builder set start up and pump filter cleaning time. Runs 12am-2am clean cycle runs 2750 rpms n from 2am-8am 1200 rpms
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New construction newpool owner
    Hi there Anthony, welcome to TFP,
    Plenty of info here,'so enjoy the forum, and ask us questions when you need too.
    Essential Links:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    And, of course, you will need one of the Recommended Test Kits to properly manage your pool. I use the TF-100 because it's the best value and they have a freshness guarantee. You can order it here: TFTestkits.net. They ship fast - you should have it in your hands in 2-3 days with normal shipping.
    Jul 2015
    Patterson, Ca
    18
    Thanks everything I've read here an some experience with chlorine ph n water alkalinity I'm starting to understand a lil more. Watched some good you tube friendly sites.I'm in the process of slowly bringing my alkalinity down its at a 130 n ph is at 8 chlorines n tc is good any suggestions I've added a total of a gallon of acid in a 2 week period waiting for test tmw
