Results 1 to 10 of 10
Thread: Bleach vs 3" Tablets
    Jun 2015
    Mansfield, TX
    7
    Is it really preferable to use liquid bleach as a chlorine source instead of the 3" tablets in order to keep CYA levels from getting too high? I'm new and still reading...eyes are almost crossed now.
    18,000 gallons
    In-ground
    Gunite
    DE Filter
    Aug 2013
    Arab, Alabama
    422
    Re: Bleach vs 3" Tablets
    Without a doubt, bleach is the preferred method of chlorinating your pool! Pucks add CYA to your pool and the only way to lower your CYA is to dilute (water replacement). Pucks can be useful, but they are a terrible source for primary chlorination.
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    38,271
    I would just append this to the end of jaduck's post:
    ... unless you are in a area with a lot of rain, and a short season where you at least partially drain the pool for winter.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    The other option is a higher % chlorinating liquid. Texas has HASA Dealers that sell 12.5% chlorinating liquid. I'm not sure of your exact location, but there is a HASA dealer in North Richland, TX.
    Support the site
    Jul 2015
    Patterson, Ca
    18
    What about if ya live in a highly hot area n dehydration is very high n putting in a couple inches a week it seems but I'm new too so any advice eventually I'll detour to this sites ways fully. Sorry a beginner too
    17k g, IG free formed, plaster/bella blue,varaible pump, cartridge filter, with water feature.New build 6/17/15 builder set start up and pump filter cleaning time. Runs 12am-2am clean cycle runs 2750 rpms n from 2am-8am 1200 rpms
    May 2013
    Fort Lauderdale, FL
    423
    You need to know your CYA level first. If it's low, then by all means use the pucks. If it's high, then only chlorine/bleach so you don't raise the CYA too high.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    It's worth noting that Cya builds up as water evaporates, as with other dissolved solids. Replacing water because of evaporation does not lower Stabilizer (Cya) levels no matter the amount of evaporation you have. Generally it builds up faster in hot dry climates with little rain.
    Essential Links:
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I haven't used a puck in three years, only bleach, primarily from Aldi's. I get comments all the time about how good the water looks. Thinking about it I don't think our current pool has ever had pucks in it since we set it up.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jun 2015
    Mansfield, TX
    7
    Thanks everyone! I am checking into bleach from Aldi as well. My CYA is between 30-40 so not high (I just drained 3' and refilled). I'll continue with the bleach as my primary chlorine source and will just use the pucks to increase CYA if it gets low. I have about 30# worth of pucks in the garage...
    This...I have about a 4 months swim season, then we pump it halfway down and cover for the winter. I shock with bleach upon opening, then use pucks to raise the CYA each year and then bleach to maintain after.
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
