Thread: Intermatic Timer Problem
    Jul 2015
    Margate, FL
    2
    I just replaced my timer mechanism and there seems to be a strange problem. The timer gears are only visibly moving when the timer is switched on manually. As soon as the timer goes off (I'm assuming) or is turned off manually (confirmed), the gears stop turning. I am stumped on this one. Any help would be greatly appreciated. I tested the lines to the timer and they are live when the timer is switched on or off just as they have always been and the timer kept time for years until the motor went out recently. Clueless.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intermatic Timer Problem
    seth, could you post a picture, it worth a thousand words The new one may have a different wiring or connections...
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    I think your problem is, your timer line is connected to its own output, so it locks itself in Off when it is Off. Check the wiring. It is one wire connected wrong. Likely.
    Jul 2015
    Margate, FL
    2
    Cowboy, thank you for your quick reply and offer to help. I actually took another look and realized I made a slight mistake. Had a line and load reversed. Ugh!!! Silly me. Problem solved. Seems to be working fine now. Thanks again!
