Thread: Pool dummy 1
    Jul 2015
    Houston, TX
    1
    Pool dummy 1
    Hi all! I'm Macey. After my swim plans fell through with friends I made the rash decision to go and buy a pool. Never had a pool in my life and know absolutely nothing about it. Well, here I am a week later, a pool owner, and feeling as ignorant as ever. HAHA Everytime I google an issue this site comes up so here I am! Happy to be here and excited for someone to help guide this "dummy" to a clean and clear pool. Thanks!
    38,449
    Re: Pool dummy 1
    Welcome to TFP!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Pool dummy 1
    Hi pool dummy!
    the smartest thing you can possibly do, is get yourself a 1st class test kit. Almost everyone on this uses, and swears by the TF100.
    you can only get them online. TFTestkits.net
    This kit will allow you to test everything in the water that you need to.
    In the meantime, take a few minutes and read the ABC's of water chemistry. This is just a description of what things like FC, pH, CH, TA and CYA etc are, and how they play together in the pool.
    Then, bookmark the recommended levels. These levels are where you want each water parameter to be.
    And, learn how to use pool math. Its pretty simple really. Just play around with it a bit.
    http://www.troublefreepool.com/calc.html
    Of course, if you have any questions about any of this stuff, or anything else, just ask, and lots of folks here will be willing to help out!
    Enjoy!
    Divin Dave,
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool dummy 1
    Welcome to TFP!
    Here are a couple more resources:
    1. Chlorine CYA Chart
    2 Recommended Pool Chemicals
    3. Recommended Levels
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool dummy 1
    welcome, +1 on the TF100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Pool dummy 1
    Welcome to TFP!
    Please add your pool info to your signature so we can better assist you. More on that here, Pool School - Getting Started
