Thread: plaster verses pebble sheen
    Jul 2015
    Tucson/Arizona
    1
    So my husband and I are getting ready to redo our in-ground pool. The plaster is peeling and the equipment needs to be replaced, we live in Tucson Arizona
    My first big question is should we just re-plaster the pool or change to pebble sheen? we have not received bids yet but I am assuming the pebble sheen will be more expensive.
    Is it worth the extra expense for pebble sheen or just spend the money on good pool equipment?
    Desert Rat
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: plaster verses pebble sheen
    Plain white plaster, for a Tucson pool, will reflect the most heat.
    Even the lightest pebblesheen will be less reflective.
    Any pebblesheen surface is going to be more durable than plaster alone.
    It will also make the pool more contemporary. The coping and waterline tile are the next most visible features that lend to the value of the pool when thinking of property resale.
    Think of it like the new cabinets and countertops in your kitchen.
    Better equipment can lower running expenses (2sp or VS pumps)
    Think of it as replacing the HVAC, not visible but beneficial long term running of the pool.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    I say call Pool Builders and get quotes for your area. Make sure to get at least 3 but try for 5 quotes and let them know you are getting other quotes.
    Kim
