Thread: Can't Program the Hayward SP1500ft Timer
    Jul 2015
    Ashland, MA
    1
    Hi all. I have the Hayward SP1500t timer unit installed and when I go to program it, it doesn't beep indicating that it's being programmed. I've checked all the connections and they all appear to be okay. The timer was working last year.
    Any suggestions?
    Thanks
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Can't Program the Hayward SP1500ft Timer
    Welcome to TFP!
    I don't use times, so I cannot help, but someone should be along shortly to assist you.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
