Thread: Kreepy Krauley issues/suggestions
    Apr 2015
    So. Cal.
    139
    So we inherited a KK with the house and pool. We have an auto pool cover that is on 90% of the time when pool isn't in use. I cannot seem to keep the pool bottom clean. KK runs for 4 hours every evening?
    My other issue, which I've just recently noticed, is that tiny air bubbles are coming out of the return port. When I remove the KK, they stop, which leads me to believe the hoses are leaking/sucking air somewhere. The hoses are old for sure just by looking at them.
    My issue is, a hose replacement kit is about $200. The KK itself is about 5 years old from receipts/paperwork I found with the house. Is this normal for the KK to leave this much behind? Even if we don't use the pool for a week, with the cover on and it running 4hrs a night, when I open the cover, there is all kinds of stuff in the bottom. I end up using the vacuum attachment to get it all clean.
    So spend the $200 on new hoses, or put it towards a better cleaner. Or suggestions on making the KK work right, lol.
    And are all vacuums as load as this thing? *hmmmmmmmmm....tick tick tick*
    13000 Gal rectangle gunite w/Aqua-Glass IG lap pool built in 1987 resurfaced (Aqua-Glass) in 2010, Hayward Max-Flo VS pump (model SP2302VSP)
    Rheem Gas Heater 266,000 BTUH (P-M267A-EN-C), Hayward Pro Grid D.E. Filter model DE3620, ThePoolCleaner, CoverPro safety pool cover, TF-100 test kit w/SpeedStir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Kreepy Krauley issues/suggestions
    Sure sounds like you have a suction side leak somewhere.
    Apr 2015
    So. Cal.
    139
    Well I'm assuming my leak is coming from the hoses somewhere between the KK and the suction port. When I disconnect the hoses from the suction port, the bubbles stop.
    I still don't get why there is so much debris left on the bottom.
    Any suggestions? Or do I just get rid of the KK. Which = $$$$
    Thanks.
    May 2015
    Chickasha, OK
    184
    If the hoses are sucking air, the Kreepy isn't seeing enough suction out there on the end to pick everything up.
    You should be able to pick up individual hose sections at your local pool store. It will probably cost more than buying the whole "kit", but you could replace them one at a time, starting with the ones that are obviously in the worst shape (i.e., the ones that spend the most time at or above the surface of the water).
    Do you have any extra hose weights? You might try adding enough weights every 2 or 3 sections to keep them all below the water line. This will fix your suction-side air leak problem, but not the lack of suction at the Kreepy head.
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
