Thread: Get a pentair variable to run for 24 hours
    Ok sometimes I need for my pump to run for 24 hours. Does anyone know how? I asked Pentair but I guess I got the wrong person. I have an intelliflo variable speed. Thanks Dave
    13000 gallon fiberglass, cartridge filters pentair Intelliflo Variable speed Programmable Pump separate booster pump solar panels on roof
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Re: Get a pentair variable to run for 24 hours
    My manual says "To run a speed without stopping, set the START time one minute after the STOP time. Example: A single speed will run non stop if programmed with a START time of 8:00 AM and a STOP time of 7:59 AM"
    I'm not sure that answers your question or not because I'm not really sure what your question is.. Tell us what your pump is currently programmed to do, and what you want it to do differently.
    I'm just guessing here, but I suspect your pump is scheduled to run for a set period of time. You want it to run 24/7, so you set a manual speed and push start and off it goes, but later you find the pump is off. If this is not the case, then tell us a few more details about what you are trying to do, and maybe someone here can help.
