Thread: Lighting placement - 20x40 double roman
    Jul 2009
    Washington, DC area
    23
    I'm remodeling my 20x40 double roman end vinyl pool. I am putting in lights, where there were none. Pentair intellibrite color. I cannot decide on placement. The pool guy says 2 across from each other, i was thinking 2 on one side (the flat side facing away from grill/ seating area.
    What would be the optimal placement and number of lights?
    Thanks
    21x40 roman ig vinyl (don't know the gal offhand)
    Pentair Tagelus 325lb sand filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Re: Lighting placement - 20x40 double roman
    Definitely face away from house and seating area to avoid glare.
    Apr 2013
    Sacramento, CA
    2,769
    Both on the same side facing away from the seating area.
    Jul 2009
    Washington, DC area
    23
    ok thanks. the pool is perpendicular to the house, the seating area is to the. so i should put the 2 light on the right side facing the left?
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    That's right.
    You will get zero glare and maximum effect of the backscatter and reflection off the far side of pool.
    With the intellibrites you will get the best of their light show that way.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jul 2014
    New England - MA
    310
    Do you have a 2D pic you can attach? I assume when you say "on the right side facing the left"... that the right side wall is one of the 40' long walls. If so, you should be good. What color plaster are you going with? If it's a darker color you may want to consider 3 lights.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
