Results 1 to 13 of 13
Thread: Some questions about SWGs
    Sep 2014
    Los Angeles CA
    40
    I'm thinking about getting a saltwater chlorinator for the 18K pool. Of the ones on amazon people seem to like the Pentair Intellichlor and the hayward goldline ones the most. Are these the favorites on here too? What about the Solaxx CLG10A?
    Around the cheapest I could find the intellichlor IC40 is for $745.00. Is this a good price? Is the power center and cell all you need? Is it best to leave it up to a pro installation and if so roughly how much would it cost to get it installed? If you decide to switch systems say between a hayward and the pentair could they be more easily swapped once one is installed?
    38,252
    Re: Some questions about SWGs
    I have had a few Hayward SWGs ... there are nice middle of the road SWGs that are very common which means you can find help more easily.
    The Pentairs have a few downsides. 1. Without their automation system, you can only change the SWG output in 20% increments. 2. Since there are electronics in the cell, the replacement cells cost more.
    Installing the SWG is pretty easy. Just hook up power and a little bit of PVC work. Swapping between systems would not be "easier" since the cells are going to be different sizes and may in fact require more PVC work than the first install.
    I would recommend you look for a SWG that is 1.5-3 times the size of your pool. So, a 40k cell is the right option.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    The power center and cell is all you need for it to function, but the pentair only has 20% increments if you don't use their automation system. The Hayward gives you smaller increments, but I don't know what percent they are. I installed a circupool si60+ earlier this year. If you are handy with plumbing and electrical, you can tackle it yourself. If not, have it installed. Not sure what that would cost. Depends on your setup and whether they have to run new wire or anything. If everything is there and they are just installing the swg, I would expect $300-500. The systems usually don't directly replace another brand. The cells are usually different lengths, so you would have to do a little plumbing rework to swap brands.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2015
    kingston springs, tn
    102
    I have an 18k gallon pool built 10 years ago. Installed an Intelliclor IC40 back in May. Went with the IC40 considering the flow switch is built into the cell thus taking a few less inches of pipe space. It has reduced maintenance 50% at least and the water is perfect. I should have bought one years ago. No more cracked skin on fingers from Handling chlorine pucks. The price you mention is a good one. We paid right at that on eBay. Pentair warranty is less if you don't have a pool installer connect it. We have a friend that we used when registering the warranty.The incremental adjustment 20% at a time has not been a problem for me. We set it at 40% and run the pump about 8 hours per day due to an increase in water temp due to the recent hot weather.
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have a pentair and it works great. But jblizzle is right, it has a couple of minor downsides.
    The Hayward works just as well, and if something goes wonky, its not as expensive to replace a part, or the cell.
    go with a cell rated for at least 40K gallons.
    Divin Dave,
    38,252
    Well I have to say that this is much more civilized than a Ford/Dodge/Chevy truck discussion
    But, Cummins is the King
    Sep 2014
    Los Angeles CA
    40
    I see a lot of cons for the pentair but what about the hayward?
    38,252
    The Hayward has a common problem where a current limiter on the board burns out making it stop working. A pool guy or Hayward will try to get you to replace the board for $100s ... or you follow the threads in the forum or YouTube videos and solder on a new part for < $5
    Honestly that is the only downside I know of ... and this has not happened to either of my systems.
    The Hayward has a knob you turn to set the % output in down to 1% increments and the replacement cells are cheaper.
    Sep 2014
    Los Angeles CA
    40
    alright how many types of aquarites and cells are there I see a billion different names like AQR9, PRO-SD-40KIT, turbo cell t cell 9. Theres just a 25 and 40K pentair right?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Pentair makes IC20, 40 and 60 for 20k, 40k, 60k. It is recommended to get SWG with 1-1/2 to 3 times the capacity of your pool. I have 20k gal pool and IC49. Can't help with the other billion!
    Mar 2007
    San Rafael, CA USA
    12,082
    I list the Pentair and Hayward SWCG models in this post and compare their economics. You'd want to at least get the IC40 from Pentair or the T-CELL-15 from Hayward.
    Sep 2014
    Los Angeles CA
    40
    Okay so I found an aquarite system for 850 on ebay. They don't say the cell but it appears to be a T-15 based on the output of 1.45lb/day. Do you think its worth it vs the pentair ic40 for 745? Does the aquarite control work with the different aquarite cells and are they the same size to swap out? What about getting a generic cell and the control panel seperately? Regarding autopilot is the ability to work at cold temps all that big a deal?
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Look at this link:
    Full Market Comparison of Salt Chlorine Generators
    I bought a Circupool Si-30 Plus (no longer available) early this year and love it. It is easily adjustable in 1% increments. Their staff is very professional and were able to all of my answer questions over the phone. The equivalent to the one I bought is the Si-30. It has a 4 year warranty vs a 7 year warranty that mine has. Replacement cells seem to be compatibly priced to Hayward replacements. I give my SWG 2 thumbs up.
    Discount Pools is also currently running a sale that includes a free size upgrade.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
