Results 1 to 10 of 10
Thread: Third Year working on this pool chemistry
    Left pool store today...I know I need my own kit. I had one with sticks and ran out. I need to get one.
    Here are my readings:
    CH 0
    TC 3
    FC 3
    PH 7.6
    TA 100
    CYA 0
    salt 3200
    The pool is clear
    Her instructions: add 10 lbs Sea Cal 5 lbs at a time wait 2 hours between
    Add 6lbs ALK
    wait 1 to 2 hours
    Add 3 lbs PH minus
    What?????? Total mess to me! I added 5 lbs of Sea Cal that she gave me because I now realize I need harder water.
    I also added 1 gallon of Stabilizer.
    Now what?? I never seem to be able to hold the stablilizer which in turn leads to me not being able to hold chlorine unless I run the SWG at 100%.
    I do run the heater 90-92 degrees when I swim
    Help
    16 x 32 rectangular, 21K,IGvinyl, 1.5HP Sand Dollar Pentair superflo high performance pump, Pentair IC20 intellichlor chlorine generator, LED intellibrite 5g light, Raypak Heater 335,000 BTU
    38,540
    Re: Third Year working on this pool chemistry
    Unfortunately, all that is a waste of money.
    You do not need CH in a vinyl pool (although I doubt you are really 0).
    The TA is fine if not a little higher than we would recommend
    The pH is fine.
    The CYA actually may have been a good idea.
    BTW, we do not trust pool store testing any more than test strip junk. Invest in one of the Recommended Test Kits and post up the results and THEN we can offer advice.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    If (huge if) you trust the pool store readings, your pH is great. TA is actually slightly high, so adding 6 lbs of repackaged overpriced baking soda is unnecessary. Since the pH is already good and you won't need to raise alkalinity, you won't need to lower pH. Scratch the pH minus. You have a vinyl-lined pool. You don't need any Calcium. Period. There is no plaster to leach it out of, so no need to maintain a minimum to prevent it. In fact, Calcium can leave deposits on the SWG plates, so lower is better. Scratch the Sea-Cal, too. All I see that you needed was stabilizer. And when that starts showing, you'll need to raise the FC level to match. Pool School - Chlorine / CYA Chart
    Those savings right there could have more than paid for a proper test kit.
    How do you lose CYA? Have you had torrential rains? Did you drain it for some reason? The CYA test is the one the pool stores mess up the most. I hope you didn't overshoot.
    Thanks, that is what I thought. I only bought the CH 5 lb bag and did add it. On the pool chemistry page it said I should be between 50-300 for a vinyl pool.
    I added the stabilizer too. I am trying to understand the chemistry page. What is it that you recommend to use to stabilize? It costs me 31.00/gallon at the pool store!
    I am headed to buy my own test kit now. Thank you for your help. I knew she was an idiot!!! Did I ruin anything adding the 5 lb bag of Sea Cal? And yes we had horrible rains the past 2 weeks, and 85mph wind gusts. They thought it was a tornado at first.
    The girl at the pool store said if my pool was at 0 hardness it would ruin my pool heater.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    What the heck is Sea Cal. I googled it and got no relevant hits.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    That is what they gave me to raise the calcium hardness. The bag says Calcium Chloride.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Thanks. When you get your test kit, I think you will find that their CH reading of zero was totally incorrect. And you will realize that their testing service was worth exactly what you paid for it (zero).
    I think you will need to buy your test kit online. Local stores kits generally do not include the FAS-DPD test for chlorine, and you really need that one included.
    The TF-100 from tftestkits.net is your best value. And the Speed Stir, also offered on that site is wonderful. You would not regret getting it.
    38,540
    Do not try to find a kit locally, you will need to order it online.
    You can get the granular stabilizer at Walmart ... 4 pounds for around $16 I think. The liquid stuff is WAY overpriced.
    Are you using PoolMath?
    Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Water Balance for SWGs
    Thanks, I have used pool Math in the past. I am still trying to understand it. It says my pool would be 23,000 gallons. I was guesstimating from what the pool store says every time I am there. Thanks about the Walmart.
    Thanks
    38,540
    It is either called "Conditioner" or "Stabilizer" ... should be near 100% cyanuric acid.
