Results 1 to 7 of 7
Thread: Chemical help for 12x30 frame pool
    Jul 2015
    tooele, Ut
    3
    Just set up our new pool last Fri. and trying to figure out all the chemical stuff. Wish I would have found this site first! I read on Pool School I could get away with just the small Chlorine/pH test kit for my small pool. So far the only chemical I've added is 1 tablet of what I'm pretty sure is a trichlor puck in a floater. Tested the water this morning and the Cl tested at .5 and the pH was 8.2. I'm headed out to get some bleach and muriatic acid but not sure about the CYA. Should I just assume it would be 0 still? Also, we're headed out of town Wed afternoon through Sat afternoon. Is there anything I need to do to it to keep it from getting gross? TIA!
    12' x 30" Intex metal frame AG pool 1,700 gal/ Intex Krystal Clear Model 603 filter pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Chemical help for 12x30 frame pool
    Your pool is so small that when that one puck dissolves, you'll be at about 17 CYA. So I wouldn't even bother buying CYA. The smallest package will be a ten year supply. Three pucks will do it for CYA. Definitely get that FC up. And don't target too low with the pH, because the pucks will also lower pH.
    Jul 2015
    tooele, Ut
    3
    Thanks! So should I just add the bleach to raise the FC and then continue to use the pucks? And should I hold off on the muriatic acid for now?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I would use the MA to bring the pH down to the low 7s. 5 ounces of MA will get you close. Retest after circulating for 30 minutes. Add a bit more if needed.
    Then I'd get that FC up for sure. Add enough bleach to get to 5-6 FC and put a new puck in the floater when that one is dissolved. Only use 3 total pucks and then just bleach to keep FC at or above 4 FC all the time.
    Isolated Spa - 345 Gallons
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Welcome,
    You can take care of that small pool with what you have, it's a bit harder but if it goes green it's cheaper (usually) to dump and start over. My first year with a ring pool and the HTH 6 way test kit and after finding this site I never had another problem. It was so easy in fact that we decided to get a bigger pool the next year and have never had a problem. In fact complete strangers ask how our water always looks so good. I always direct them here, though the last one was a Mennonite and I may have to print some info off for him, because I don't think they can use the internet.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2015
    tooele, Ut
    3
    Thanks for the quick responses! Can I add both the bleach and the MA at the same time or should I wait for a bit in between?
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by tykayaus View Post
    30 minutes between additions and pump on 30 minutes minimum after additions. Brushing to disperse it will speed it up.
