Thread: Ascorbic Acid
    Ascorbic Acid
    Followed ascorbic acid treatment for pool stain on floor and walls.
    First, CYA high, so did a partial drain, refill. Got the chlorine down to
    0 and PH down. Ordered 1# of ascorbic acid (why we didn't order more,
    I don't know). Applied the 1# and also by TFP did the poly quat algaecide
    with 16oz. Pool water looked good (actually always looks good), didn't notice
    any stain leaving, so ordered more, which hasn't arrived yet, because of holiday.
    The last two days, the pool is getting cloudy, added another 1c algaecide, this
    am another 1c.....and brushing. The stain is a lot lighter, unless we can't see because
    of the cloudiness. We are wondering if we should wait for more acid, or start the
    sequester, followed by the chlorine, as we are worried about being without chlorine
    and the pool getting worse than cloudy. Any suggestions?
    thx
    14X29 plus 5X9 spa.........10,000 gal cement (marcite?)
    Liquid chlorine
    Hayward DE filter
    Solar heat
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Re: Ascorbic Acid
    If it was me, I'd go ahead and finish the treatment that you started, so that you can get some chlorine in the pool. Especially if it's going to take a few days or more to get the rest of the AA in. Then you'll just need to do another separate treatment. That seems an easier task then potentially slamming the pool if you get an algae outbreak.
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    Re: Ascorbic Acid
    Thank you. New here in posting and took me awhile to find the response.
    Liquid chlorine
    Hayward DE filter
    Solar heat
