Thread: back from vacation/Found odd rock in pool
    Jun 2015
    harker heights
    3
    Background info first:
    16' Intex AG, salt water chlorinator, cartridge filter
    Before leaving for 10 day vacation my levels were within range. I decided to avoid any swamp issues by pouring an unknown quantity of bleach to shock the pool (approx 30oz) and covered with factory cover.
    When I returned, the cover was mostly inside the pool, blocking the return and limiting the intake. The filter was mostly clean, so I sprayed it off. The pool was filled with 1 large backswimmer, numerous small bugs that could swim excellently and alot of surface debris. I plugged in the skimmer and tested the water. The results were:
    FC 6.8
    CC .2
    Ph 7.4
    TA 130
    CH 110
    Cya 75
    After running the skimmer for a few hours the backswimmer was gone and after a day all bugs disappeared. I though "GREAT". But while vacuuming I noticed something odd, causing this post.
    In the center of the pool, down on the bottom, I sucked up a ping pong size, white, ball like substance. It was rock like and slightly hard. I was able to step on it and broke it up. Once broken, the substance was sandy.
    What is it??? Calcium?
    How did it get in the pool? Is it something I am doing wrong?
    The water is beautiful. Clear. Clean. Refreshing.
    Any guesses?
    Butch
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: back from vacation/Found odd rock in pool
    Stray 3" trichlor puck?
    Apr 2013
    Sacramento, CA
    2,769
    I doubt it was calcium. Its hard and mine has a yellow tint.
    Jun 2015
    harker heights
    3
    Only if a bird dropped it in, TFPM only for this pool.
    Apr 2013
    North OKC Area
    300
    Sidewalk chalk?
