Thread: Waterfall Algae Prevention
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    This just occurred to me... If you look at the picture below, the brown boulders across the back of the pool house a "weeping waterfall." When the pool was built, I saw inside & it's essentially a trough that fills up and gently overflows down the rock face when running. The builder recommended running it once a week to keep it clean, but I'm wondering if that's really enough. Thoughts or recommendations?
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Waterfall Algae Prevention
    I would run it once a day for a couple hours and also brush it down each day.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I agree, once a week is not going to be sufficient. The FC will drop to "0" and start to grow in a few days and then when the pump kicks on it's going to dump it in the pool. Lisa's idea of a couple of hours a day sounds like a good one.
    Support the site
    Mar 2015
    El Cajon, CA
    31
    I have a grotto with large water fall and I have it programed to run for 30 minutes per day and do not have any problems with it; also, have water slide with two sheer descents and those I have run for 15 minutes per day as well and no problems with them either. If pumps do not move water thru descents and water falls no chlorine gets to those areas.
    IG, pebble tech, 25K gallons, grotto, SPA that spills into pool, water slide, two other water falls. Equipment Pentair, filter FNS + 60, pool pump 1.5HP single speed wisperflo, spa 3 HP single speed wisperflo, grotto/ slide 3HP single speed wisperflo, waterfall 2HP single speed wisperflo, minimax NT 400K btu, Hayward XL pool vac, SWG IC60, compool 3800 automation, built 2007.
    Sep 2014
    Cibolo, TX
    89
    Thanks everyone! I set up the waterfall for 1hr per day.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    I would also spray with with diluted bleach once a week if you see any algae growing on the surface
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
