Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: The biggest problem with this TFP method!
    May 2015
    River Falls, WI
    124
    The biggest problem I see with following the advice on this forum is the crystal clear water! I mean, itís infuriating to be able to see every kernel of sand at 8í.
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in Ď70ís, has 8í deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: The biggest problem with this TFP method!
    A close second is the inability to enjoy swimming anywhere but home. To even go swimming anywhere but home!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Be sure and go on record in our...."Complaint Dept." forum.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    It makes me feel good to be underwater in the shallow end, and seeing the light at the deep end, 35 feet away, with crystal clarity.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Jun 2015
    Phoenix, AZ
    73
    That's all you can complain about? How about lugging gallon bleach bottles, overfilled recycling bin with empties, and having two 35lbs pails of pucks that'll take forever to use?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by chyvan View Post
    That's all you can complain about? How about lugging gallon bleach bottles, overfilled recycling bin with empties, and having two 35lbs pails of pucks?
    I've got a 40 gallon trash nearly full of empty bleach containers. One of these Mondays I need to pull a midnight mission of dispersing them in my neighbors' recycling containers on the curb.
    Isolated Spa - 345 Gallons
    May 2014
    Cookeville,TN
    97
    Quote Originally Posted by wrems View Post
    At the risk of turning this into a serious thread, my biggest problem is that I tell friends and family about the method, I mean just the basics so as not to shock them (pardon the pun); and all I get is "really; not "REALLY!", but just the regular "really". And they just continue as before, which is fixing their pools when they go bad and following the pool store advice on chemicals and thinking that's just how it has to be.
    I think these folks respect my opinion, and I think I'm keeping it simple explaining it; talking mostly about keeping free chlorine at a level based on CYA; not just 1-4; daily testing and replacing consumed chlorine as determined by the FC level during the test; using only chlorine (usually bleach) as sanitizer and as an algaecide and other, mostly grocery store and hardware items and that's it. No weekly shock or slam; just a few minutes per day to test and replace. They don't disagree with the method. They just won't do it. Is it possible that someone could hear or read about this method and understand it and not want to try it? But that's what I get.
    They understand the terms. They even understand the problem with overstabilization and using the term CYA, so it should make sense to them that the higher the CYA, the higher the FC has to be just to do the same work, but I've not got but one person to try the method and his spouse buys some of the unneeded items and puts in the pool, so he's not really doing it but wants to.
    My sister-in-law actually fixes peoples pools. Usually really, really bad pools where the pump has not been turned on for a year or more, but she also maintains a few people's pools for them. I asked her if she had ever heard of "BBB" or TFPC or setting the FC based on CYA. She said "no". I explained the differences and sent her a link to the calculator, the pool school, the recommended levels, and the FC/CYA chart. Have never heard back from her. Not a "thanks but no thanks"--nothing! Does she think I'm trying to be a know-it-all. I don't know.
    Anyone else get this non caring attitude from others about TFPC?
    7600 gallon; 18'X54" round; vinyl; sand filter and 110V pump, 2-speed.
    Near Cookeville, TN--1/2-way between Nashville--Knoxville along I-40; Highland Rim part of the Appalachian Plateau (we call the Cumberland Plateau for the southern half of this geological region).
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    There are people that want to learn new things, and people that don't. That's just the way it is. Nothing much you can do about it.
    Jun 2014
    15,023
    I am extremely frustrated with the clarity of my pool. The wife reminds me EVERY TIME see sees the smallest bits of debris that the pool needs to be vacuumed. Uhg. At least when it was cloudy there were places for junk to hide.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,424
    I HAD two (notice two) that would not hear me. They both had clear water so....................Well with one it caught up with them! It got cloudy over one day. The next day it was green all over the side and bottom of the pool! "What do I do?????" they asked the pool store LOL The pool store tested their water and tried to sell them $150 of stuff!
    They called me and asked if I would come over with my test kit. I did and their CYA was OUT of there! I did not even bother trying to dilute it.
    I sent the wife to the store to buy bleach "BLEACH??????" LOL Yes bleach. The husband I set up draining the pool. He only wanted to drain about 50% which I though was a good idea being in FLorida and our high water table.
    It took 3 50% drains to get the CYA down to 30! While it was filling each time he was adding bleach and using a sub pump to move the water and bleach around.
    His pool is clearer than it has ever been and they are loving their own test kit and their BLEACH! LOL
    The other pool? I am here when then need me.
    Kim
    Jun 2015
    Mesa/Arizona
    1
    This TFP method is driving up my electric bill, as I want to have my pool light on all the time so I can see the pretty blue color..
    12 gal freeform, IG pebble, SWG, Floor Pop-ups, 2X Intelliflo SVRS, Jandy (4) Cartridge Filter, Autofill, K-2006 test Kit.
    Adding to Richard's comment... The other day I walked by a hotel with an outdoor pool that was visible from the sidewalk, maybe 10 ft away through a metal fence. The water was blue, but cloudy and there were at least 20 people swimming in that goop... A part of me wanted to test the water to see what the chemistry was like but I didn't have a test kit handy, nor did I want to get arrested for trespassing.
    A few years ago, prior to being a pool owner, I would have thought nothing of it.
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    JoyfulNoise's Avatar
    May 2015
    13,177
    I will no longer swim in other people's pools....unless there's a TFP logo hanging on the pool fence.
    Honestly, we went to a beautiful resort this past weekend for the 4th of July and I was sitting on a lounge chair watching the wife and kids float by in the "lazy river" pool. Now the water does have perhaps 100 or more people in it BUT it stunk of CCs and was barely visible to the bottom (you could make out peoples feet but not get a proper toe count). All I could think to myself was, "yuck, that is some nasty water!" The entire time I was getting razzed by my family for sitting on the side lines. My response to my wife was, "See, the big chunky dude that is floating on the inner tube? He's consumed about 4 of the 6 beers in his ice pail already and has not left the water....ENOUGH SAID!"
    Yip, it's sad but true, TFP turns even the most mild-mannered person into a pool-snob!
    Matt
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I can tell you how to fix that.
    Get yourself a retrofit LED color changing lightbulb. Then you can see lots of different pretty colors!
    Quote Originally Posted by phoenixrhino2 View Post
    Aint it the truth! ugh!
    The biggest problem I see with following the advice on this forum is the crystal clear water! I mean, it’s infuriating to be able to see every kernel of sand at 8’.
    Divin Dave,
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    LOL
    I like the logo on the fence idea!
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    My problem is the water is never clear enough. Everyone who sees my pool says they have never seen a pool so clear. But I seem to always strive for it to be just a bit clearer and sparkle just a bit more. Then there is the problem that I can see a single ocotillo leaf at the bottom on the other end of the pool. (For those of you who don't have ocotillo, a large leaf is about 1/4 inch long by about 1/8 wide.)
    chiefwej
    May 2015
    13,177
    Quote Originally Posted by chiefwej View Post
    I can make out a single mesquite leaflet at the bottom of the deep end. I then command Kreepy Krauly to go and fetch it yet he seems to just wander aimlessly about the bottom, lazy little bugger....
    Matt
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    This. Just can't do it.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jun 2015
    N Tonawanda, NY
    469
    A co-worker asked me today how the pool is coming along. I responded that its the cleanest pool in town. He then showed cell phone pics of his pool, looks OK. He'll be seeing my pics tomorrow.
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,424
    Throw a coin in the water and show him how you can see the head/tails on it!
    Kim
